Yamaha receiver settings
RJaco
I just got a Yamaha 6140. I hooked up to my front speakers and it worked just fine. Then today, I got the center channel and hooked it up. It didn't work. I messed around with the settings and now it works, but I don't think my left front is working. They all work great when I play music through the tuner but not when on dvr viewing. I have been looking through the manual trying different things but haven't found what I need as of yet. I will run the auto setup later. It may be a while before I get all my speakers set up but would like to you the front, center and sub for now. Can anybody help a poor dumb Okie out?
Post edited by RJaco on
Check you connections 1st off.
Make sure they are clean and secure.
Make sure they are in the right place.......start there see what happenns.
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
