Yamaha receiver settings
RJaco
RJaco Posts: 113
edited January 2009 in Electronics
I just got a Yamaha 6140. I hooked up to my front speakers and it worked just fine. Then today, I got the center channel and hooked it up. It didn't work. I messed around with the settings and now it works, but I don't think my left front is working. They all work great when I play music through the tuner but not when on dvr viewing. I have been looking through the manual trying different things but haven't found what I need as of yet. I will run the auto setup later. It may be a while before I get all my speakers set up but would like to you the front, center and sub for now. Can anybody help a poor dumb Okie out?
Post edited by RJaco on
  • Motzart
    Motzart Posts: 1,075
    edited January 2009
    Check you connections 1st off.
    Make sure they are clean and secure.
    Make sure they are in the right place.......start there see what happenns.
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
