Point of no return...
lilwaun
Need some advice. Purchased my first set of Polk's about 6 weeks ago, SDA 1's. Got em home, one bad tweeter, one bad mid. I figured this was "ok", got them for $200. So I found a used replacement silver faced SL 1000, sounded completely different then the other 3. Wasn't sure why, so I ordered one RDO-194 and a MW6503 to see what I got for sound. Polk CS sent me two RDO-194's by mistake, so being a little antsy I kept them and replaced a tweeter on each speaker. Much different sound than I was receiving from the previous SL1000's. Now I may be at the point of no return...are these speakers worth sticking $48 bucks a driver to have them all replaced? 4 tweeters, one or maybe all four mids? Any advice would be of help.
Post edited by lilwaun on
They generally say if you replace one, replace all for the very reason you listed. But SDA's are a unique speaker, and I would say it is worth the cost of replacing what needs replacing.
Welcome to Club Polk.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
That's what I figured. I think I will replace all the tweeters and the mid that is bad and evaluate from there. Thanks.
