tsi 100 bi wire
bildo
bildo Posts: 1
If I want to bi-wire the tsi100 does the top connection go to the tweeter, and bottom to the mid or is it revearsed.
Post edited by bildo on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    Easiest way to find out is to hook it up and find out which one works when you turn it on, typically though the top is the tweeters and the bottom is the woofer. Make sure you remove the jumper that connects the two sets of posts though or it will do you no good. Also usually it is recommended that you use the surround back L/R on your receiver for the woofers and the front L/R for your tweeters, but refer to your manual on how to Bi-Amp your speakers and also make sure you set your speaker settings to Bi-Amp. Oh, and welcome to Club Polk.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • dorokusai
    dorokusai Posts: 25,628
    edited January 2009
    bildo wrote: »
    If I want to bi-wire the tsi100 does the top connection go to the tweeter, and bottom to the mid.
    Yes.
