No ground wire for rega tonearms
zeppage2
Has anyone experienced hum/buzz with these tonearms?
If so, what is the remedy?
regards, Mark
regards, Mark
Post edited by zeppage2 on
Are you saying the turntable has no ground wire or just the tonearm? Also, what kind of cartridge are you using? Some Grado's are notorious for having a buzz/hum.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
No, I haven't purchased the tonearm yet; merely anticipating problems...
regards, Mark
No problems."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
