No ground wire for rega tonearms
zeppage2
zeppage2 Posts: 196
edited January 2009 in Electronics
Has anyone experienced hum/buzz with these tonearms?:confused:
If so, what is the remedy?
regards, Mark
Post edited by zeppage2 on
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    Are you saying the turntable has no ground wire or just the tonearm? Also, what kind of cartridge are you using? Some Grado's are notorious for having a buzz/hum.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • zeppage2
    zeppage2 Posts: 196
    edited January 2009
    No, I haven't purchased the tonearm yet; merely anticipating problems...
  • Face
    Face Posts: 14,340
    edited January 2009
    zeppage2 wrote: »
    regards, Mark
    No problems.
