4 Ohm Advantages
Appears LSi family of speakers are 4 ohm. Since they require an additional amp to drive them efficiently, what is the advantage of 4 ohm. Are most competitor speakers also 4 ohm?
Post edited by Murray1 on
Welcome to Club Polk. I can't answer whether or not there is an advantage of 4 vs 8 ohms (I'm not sure there is-I think its just a design difference), but just so you know, the LSi's (at least the LSi9's) can dip below 2 ohms at certain frequencies. 4ohms is the nominal imedance rating. Actually all speakers no matter there nominal rating vary imedance at different frequencies if I understand it all correctly.
EDIT:
Here's a link to a chart on the LSi9. Look at Chart #4 for the impedance curve-its lowest at ~50Hz.____________________
Pool: Atrium 60's/45's -
hmm, I can't find my printed copy. But it appears that the whole site is down-perhaps it will be back. Maybe they forgot to renew the domain name.____________________
Well I found that they changed thier domain name, here is the link to the original page:
http://www.soundstage.com/revequip/polk_lsi9.htm
But it appears that the link is still coded to go to the old name.____________________
Very good question, I have Linn speakers and they are also 4ohms.
I think that all Linn speakers are 4ohms.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I am sure there is a good reason for this. I am not an EE or a speaker designer so I can only guess on what and why.
Then again there might be no reason. It all might be a conspiracy for us to have to go out and buy higher end equipment that can handle the lower impediences.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
There is no "advantage" for speakers to run at 4 ohms vs 8 ohms. On the contrary, it is less stressful to the amplifier to run higher ohm rated speakers. It is what it is though, and if you want the sound that the Lsi's produce, be prepared to get an amp that is comfortable with a nominal impedence of 4 ohms."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
This should take you there.... (web archive to the rescue again)
Michael
Edit - 4 or 8 ohm is not a quality determination, simply an engineering decision based on drivers used and crossover design. (I do wonder if they design a speaker as 4 ohm at least in part so there is a better chance it will end up being driven by more than a cheap AVR though - The LSi's certainly benefit from a decent amp.....)Mains.............Polk LSi15 (Cherry)
Much of the problem today is that most tweeters are 4ohms, especially mid and high end models."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well, if your amp is capable, you get more watts out of the amp versus eight ohms.
This is true. Or conversely it could be stated that the biggest problem is that most receivers aren't 4 ohm stable:cool:"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
Thank you. If you are stepping up to higher end audio you should have an amp capable of running 4ohms. I like 4ohms myself. The problem is with LSI's they are priced too low, and the idiots that sell them 9 times out of 10 have them setup wrong.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Sweet-I'll have to bookmark that archive site.
For archive's sake of my own,
Here is the Impedance Chart both linked to my photobucket and attached.
