Integra DTR 7.1 receiver.. any interest??
faster100
faster100 Posts: 6,124
edited June 2003 in Flea Market
I am considering selling this fine receiver, This ain't no Circuit city special :)
I bought this about a year ago, then the list was $1300.00
THX cert, dd, dts, dts es, ex, 100x6 external amp for 7.1 needed.. I have the box, and packing and manual.. This was sold to me by a local hi-fi shop.. it was a B stock not refurbished.. I was told it was for a blemish or something, They don't know exactly when they get them, works great and looks great.. never did find any marks on it.. has the learning remote.. with small lcd screen on top..
I would really like to get $675.00 or best offer.. what i consider the best offer, not the current offer.. so i will shoot down offers as they come until i get what i want.. or it doesnt sell, good enough??
Thanks for looking
DTR-7.1
Clearly, this is no home theater centerpiece for the mild-mannered
Power Rating (8 ohms) 100W x 6
Power Rating (6 ohms) 130W/ch
Wide Range Amplifier Technology (WRAT) 10Hz-100kHz
Audio Inputs 3
Assignable Digital Inputs 4
Multi-Channel Analog Inputs 7.1
DACs 96kHz/24-bit x 8
S-Video Input 5
Phono Input
Component Video Switching 2 Pro-Grade
Multi-Room/Multi-Source Powered & Line
Pre-outputs 7.1
AC-3 RF Input for LD - no
Digital Outputs 1
Upgradeable Processor - no
THX Certification Select
Surround-EX / DTS-ES
Dolby Digital Decoding
Dolby ProLogic II Decoding - no
DTS Decoding
Cinema Re-Eq
Optimum Gain Volume Circuitry
Power-On Volume Memory
IntelliVolume
OSD
Learning Remote w/ Macros Back-Lit
Multi-Way Binding Posts
Remote Interactive (RI) Compatible
Assignable 12-Volt Triggers
Multi Room Remote Control Connection Mini & RS232
RS232 Port Control/Upgrade Control only
Detachable Power Cord
DTR-7.1
Whether you are building your first home theater or upgrading your existing system, you need a good, solid foundation. You also need a receiver that's not going to be obsolete in six months. And, preferably, one that offers a mix of high-end construction, full-bandwidth power, versatile digital processing, comprehensive connectivity and an attractive price.
Well, you found it. In addition to built-in Dolby Digital, Pro Logic, DTS and DTS-ES Matrix decoding, this masterpiece of engineering decodes the latest surround-sound sensation - THX Surround EX-encoded DVD's - and provides 6.1 channels of independent amplification, so you can immediately enjoy the benefits of THX Surround EX (greater 3-D effects and sound location) without having to buy and hook-up an external amplifier.
Another very important advantage - THX-Select certification - which means when other A/V receivers start to feel the strain, the DTR-7.1 kicks into higher gear to match the pace of the action - because it's designed and officially certified to be driven hard.
The DTR-7.1 also introduces a slew of other features never before available in this price range, most notably extensive systems-integration capabilities for custom installation setups. For example, it has a powered Zone 2 audio output, which means, unlike most multiroom-capable receivers, you don't need an external amplifier to enjoy a stereo audio source (radio, CD, MD, LP, or cassette) in the main room, while at the same time your partner listens to a different stereo source in another room.
Other custom installation features include line-level outputs for a second zone amplifier to power whole-house systems, an RS-232 terminal that allows you to use touchscreen controllers from other manufacturers, an infrared-sensor input on the back panel so you can control the DTR-7.1 from another room or if it's inside a cabinet (with optional accessories), and two assignable and configurable 12-volt triggers to activate your power amps, drop the screen, close the drapes, dim the lights - you name it.
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    edited June 2003
    what am i boycotted in the flea market?? :) Not even a comment?? about this receiver
    what is it?? price ya cheap skates, LOL it looks sweet....
    ok $645.00 + shipping come on, give me a break here guys.. if you buy the receiver, I will throw in the psw404.........
    for $275.00 + ship :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Tour2ma
    Tour2ma Posts: 10,177
    edited June 2003
    Well so you don't feel lonely... It's nice looking. Your price/ obo approach is fine by me.
    Were I interested, I would have no qualms about doing a deal with you. Good luck...
    More later,
    Tour...
    Vox Copuli
  • stevelarrison
    stevelarrison Posts: 63
    edited June 2003
    Your description doesn't mention it, but looking at the newer version Integra receivers (DTR 8.3), there is an intriguing feature called Net-Tune™. Does your receiver support Net-Tune™?
  • gidrah
    gidrah Posts: 3,050
    edited June 2003
    Tour said it right!
    If I was in the market for a receiver like this I would probably be all of it. I mostly by roughs and look for the diamonds inside.
    Make it Funky! :)
  • faster100
    edited June 2003
    No that's a new feature...
    Thanks Guys, i was kinda kidding.. about the boycott.. But seems i can't sell anything lately.. I'm in a slump :(
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2003
    My question is WHY would you want to sell such a nice cutting edge AVR at such a low price? I'd hang onto that bad boy if I were you.
    Doc
    SVS
  • faster100
    edited June 2003
    I was thinking the pioneer elite was better for my setup, vsx45tx... and was told that was the reason for my 70's being bright?? So i thought i might get a different receiver..
    Not real good reasons i suppose,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited June 2003
    Doc
    I think i will Doc, get my priority's straight.. get my Pb1 first..
    Not for sale anymore!!!!!!!
    If you were interested you waited to long
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • izafar
    izafar Posts: 822
    edited June 2003
    Faster,
    I was also once VICTIM of RTi70's brightness. To get rid of the brightness I had to add a separate amp and am using my receiver as Preprocessor. I would suggest you to try a separate amp with your receiver. You can start with a 2-channel amp for you mains and then can add amps for your surrounds. You should be able to get a good used 2-Chanel amp for around $200 on ebay.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2003
    Agreed with izafar, also trying some different interconns may make some subtle to obvious changes in the direction you want to go with the sound.
    -R
  • faster100
    edited June 2003
    Thanks, I changed from junk wire to monster 14-4 bi-wire and that actually calmed down some of the brightness, My wife even noticed.. I also did upgrade all my interconnects to AR's.. however i am sure better ones are out there.. Its not bright on movies thank goodness, and cd's might be caused by my cheapo pioneer dvd player.. really i should get a better cd and dvd player. was still looking at pioneer elite dvd's and cd players.. and the brightness of course is only at pretty high volumes.. i just turn the treble control down and it gets better
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • izafar
    izafar Posts: 822
    edited June 2003
    So you are using your DVD Player for 2CH music. Are you using the DAC in your DVD Player or your receiver? In my case I have always found the DAC in my receiver to be brighter than the DACS in DVD players that I have tried so far. So if you are using the receivers DAC, get a good analog interconnect and try the DVD players DAC.
    -izafar
  • faster100
    edited June 2003
    how do you use the dac in the dvd instead of the receiver?? analog interconnect?? I have all 3 hooked up, optical out, coax digital out and analog .. i never use the analog though.. figured the digital coax was better.....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • polkatese
    polkatese Posts: 6,767
    edited June 2003
    faster,
    if you use the digital out (coax or optical), then you will use the receiver's dac. Using the analog output, will utilise the player's dac.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Dr. Spec
    edited June 2003
    Good move, Faster. That's mint AVR.
    You might even try the M1.4 bi-wire - very laid back but detailed highs - not the least bit sharp and the Lowe's stuff I was using before had more brightness in comparison.
    What kind of DACs are in the Integra?
    You can only use the DACs in the DVD player if it has analog outputs. I use this feature on the DVD-2900 for DVD-A and SACD, but I could also use it for good old 2 channel stereo, too.
    The 2900 and the 3803 employ the same DACs, so the sonic signature is similar in my case, regardless. It's just that SACD and DVD-A require analog outputs.
    Doc
    SVS
  • izafar
    izafar Posts: 822
    edited June 2003
    Fatser,
    If you have hooked both analog and Digital cables between the receiver and DVD player, then you need to configure you Receiver to use one of these. I think your receiver would be configured to use Dig Coax for DVD input. Simply go to the input setting for CD and select analog. Also connect the analog cable from DVD player to CD analog in on the back of the receiver.
    With the above configuration you would be able to do A/B testing when playing a CD in your DVD player by just switching the inputs on your DVD player. I think your integra has an inteli volume feature that set the gain for each input. Just set it to 0db for both DVD and CD inputs.
    Lets us know what you discover with this test.
    -izafar
  • faster100
    edited June 2003
    Yes my receiver has a input button as well as on the osd to flip between the inputs, analog, coax1, optical1 so on, I have tried both and the analog does cut it down a slight bit.. and also i have the analogs plugged into the cd, and i use coax for dvd playback.. Thanks guys.
    Spec,
    let me look and see what the dacs in this are
    I called Integra and it was like a top secret question about the dacs, Customer service said Burr brown, and the website states
    so let me know what ya think??
    I just seen this today, sweet.. only the $3000.00 price tag is alittle steep..
    http://www.integrahometheater.com/model.cfm?class=separate&m=DTA-9.4&p=i
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
