rotel
jjeckelxz5
i'm thinking about purchasing a 1055 or 1072 cd player, and a 1084 tuner, does anybody have any feedback on these components? Also does anyone know any websites that i could get them from, i have a couple rotel dealers around me but they dont carry these components.
reciever-Yamaha rxv1700
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3
Post edited by jjeckelxz5 on
That 1072 is a fine cd player.And you can add a DAC to it if you want to later on.It has HDCD playback too!So if you add a DAC go for one that also has a HDCD option.Like an adcom GDA-700... here is link to a review. http://www.goodsound.com/equipment/rotel_rcd1072.htm
Try audiogoN and ebay.I thuoght I saw one in our fm a few months back.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Here are some audiogoN links.Email Morrow audio and ask what mod they did to the 1072.
http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1234532684&/Rotel-RCD-1072--moded-by-Morro
http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1232858295&/Rotel-RCC-1055-5-CD-Changer-+-SDA-2BTL with custom IC
I have the RCD-1072, and before that I had the RCD-855. You will be very happy with this player.
The fellas have already posted Audiogon links for you to get one.
How can you have Rotel dealers that don't carry their MAIN cd players???? Let them order you one from Rotel!
If they refuse report them to Rotel!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
your probably right the store will more then likely order it for me.
i noticed the 1055 and 1072 are the same price i was wondering if there is a difference in sound quality between the 2
also has anyone used the 1084 tuner before or can you recommend another onereciever-Yamaha rxv1700
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3 -
One is a changer whereas the 1072 is single disc. I doubt there is a difference in SQ, but with a changer, there is more risk of something breaking with all the spinning around it has to do.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
What exactly makes something an HDCD player? I have a bunch of HDCD's...and they all play just fine in my regular CD player. Is it like SACD where you're just getting the regular mix with a regular CD player...but with an HDCD player you're getting an enhanced version?
I was just looking at the Rotel CD players a few days ago and I was wondering about that.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I have the Rotel RT1084 tuner (silver). I dont have alot of time just now but will get back to ya.
Dave -
It just means that if the cd is encoded to play HDCD's the Rotel will play them. I have maybe 2 HDCD discs and the little light comes on telling me that it is.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
