Modest speakers for entry to HT?
gdb
gdb Posts: 6,012
edited December 2008 in Speakers
I've never had anything other than two channel equipment before but have recently gotten a Denon AVR-4800 to try out a HT set up. I'd like some suggestions for a matched five piece speaker set that is decent but inexpensive. I have a Velodyne sub (cheap VRP 10" ) that I hope will work OK with the new HT speakers. Anything will be a step up from the two tiny speakers built into my TV that I'm currently listening to. Thanks for any help you can offer! Geoff
Post edited by gdb on
  • dkg999
    dkg999 Posts: 5,647
    Not sure what your definition of cheap is, but the Polk Monitor series is pretty good for entry level HT. You might also look at combining a Polk SurroundBar with your sub. The prior generation of the RTi series can also be had on eBay at pretty reasonable prices and are great HT speakers.
    DKG999
  • gdb
    gdb Posts: 6,012
    dkg, do you mean the large monitor speakers? I have a pair of Mon10As but I guess I forgot to mention that I'd like compact HT speakers. My wife is gonna go postal when I change the SDA1s to SRSIIs in the living room as it is,so I need some little "girly man" speakers for the HT set up. Maybe something that'll sit on top of the SRSIIs and fasten to the wall for the rears??? :confused::D
  • comfortablycurt
    comfortablycurt Posts: 6,745
    gdb wrote: »
    If you're looking for smaller speakers, the Monitor 40's would work for fronts and the Monitor 30's for rears. You could also look into the TSi series, which is basically the newer version of the Monitor series.
    The Monitor 40's go for around 200 bucks a pair shipped, and the Monitor 30's go for about a hundred a pair shipped through Polk Directs ebay store. Their TSi counterparts are still a bit more expensive though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dkg999
    dkg999 Posts: 5,647
    I'd look for a SurroundBar (the one you connect your AVR to) and use it with your sub. Very space and WAF friendly. It will look like a girly-man speaker until you hear it.
    DKG999
