Monitor 10b
leroyjr1
For sale is a great condition pair of vintage Polk Monitor 10b's speakers in rosewood cheery veneer. Comes with original manual and boxes.
Speaker 9/10
Cabinet 8.5/10
Grills 9/10
Asking $150.00
Speaker 9/10
Cabinet 8.5/10
Grills 9/10
Asking $150.00
Post edited by leroyjr1 on
O.b.o.
Shipping? to 80863?"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Great deal!
I wonder how these would sound with tubes ?
Maybe I will look into it , if they are still availableCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Fantastic looking speakers and with boxes to boot. I would say "Good Luck on your sale" but I doubt you will need it.
Just for the record, you will get much better sound if you can get them about 10" or so off the ground and tilted back at about 5 degrees..... (could be a little off on the height, but pretty sure about the tilt) The 10's can be a little boomy sounding when sitting on the floor like that.
(Just in case anyone drops by for a listen)
wow. pretty. when did you purchase them?______________________________
F: 1pr LSi15's ebony
C: LSiC
Surr: 1pr LSi15's ebony
Surr,R: 1pr LSi9's ebony
Sub: Epik Dynasty
Outside: 4x Atrium 65SDI
Legacy Remotes (pristine): 1pr Polk 10's, 3pr Polk 7's
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
Video: Sony KDL-52XBR6 -
leroyjr1 Would you be willing to drop them off at your local "mailboxes, etc." for shipment? (They would box them up & everything on my dime.)
BTW (first...) -- has anyone out there had any bad experiences shipping 10's (e.g. misaligned mid-range drivers)?______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
best to take out mids and tweeters and put it proper boxes and shipping seperate. I have had a couple mids freeze up during shipment.
Good luckLife without music would♭ -
polkmeister wrote: »leroyjr1 Would you be willing to drop them off at your local "mailboxes, etc." for shipment? (They would box them up & everything on my dime.)
Local mailboxes ??????????????
Mailboxes, etc is a shipping store, like the UPS store."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
Haven't see any around here -
New price $135.
I'd buy them but shipping to Hawaii wud be ridiculously high... sending a 50 lb amp set me back $300 via UPS from St Louis....
You don't need speakers in Hawaii. You should be outside enjoying the weather. It's snowing here. -
Great price! Be careful shipping...
I just shipped a pair and one of the mid-bass speakers got damaged due to the magnet shifting. After reading some of the threads here, wish I would have glued the magnets or shipped the woofers separate. Lesson learned for me. -
leroyjr1 if you give me your zip, I'll look up a local shipper and see what it'll cost me. would you be willing to pull out the mid-range drivers and ask them to pack them separately? thanks______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
Yes , I'll pull out the mids for you. Zip 53223
Thanks -
I'll get right back to you in a min. about a location, and will call for pricing manana.
BTW I pulled out and replaced a mid several years ago on my Model 10's (vintage '78). I can't recall if pulling off lugs was involved, or if they have to be unsoldered. Would you mind (and be equipped) if has to be the latter?______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
I don't think they're soldered
Here are some possible locations. Are any near you?
Mail Boxes Etc
3815 N Brookfield Rd
Brookfield, WI 53045
(262) 781-3626
N78W14573 Appleton Ave
Menomonee Falls, WI 53051
(262) 251-1551
6560 S 108th St
Franklin, WI 53132
(414) 529-7374______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
polkmeister wrote: »Here are some possible locations. Are any near you?
Mail Boxes Etc
(262) 781-3626
(262) 251-1551
6560 S 108th St
Franklin, WI 53132
(414) 529-7374
About 7 or 8 miles. -
If you let me know which one is closest, I'll call tomorrow morning and see if this all makes sense cost-wise. OK with you? Would you be willing to drop them off?______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
The second listing is the closet
(262) 251-1551 -
OK, I'll check it out. If you'd like me to contact you directly once I know the score, send me your e-mail or phone by a Polk forum private message. Otherwise, I'll post here again tomorrow with more info when I have it.
Out for now.______________________________
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
PM sent
Thanks, leroyjr1. You're to be commended on your willingness to go the extra mile.
For all those other forum "listeners" out there, I contacted "Mailboxes, Etc." and got the following quote PER SPEAKER to ship the Model 10's:
1. Per their recommendation -- to "double-box" up the speakers (which would already be in the orignal Monitor 10 cartons, thanks to leroyjr1), with internal padding = $41.00 each.
2. Shipping to CA from WI: $64.00 each.
total $105.00 ea, for a total of $210.00 the pair.
Wish I lived next door. Unfortunately, my Christmas fund this year would be exceeded.
C: LSiC
Sub: Epik Dynasty
AVR: Onkyo TX-SR806
PA's: 6x NAD2400
Checked fed ex and it would be about $70 total.
weekend bump
Holiday bump
