What subwoofer cable to buy?
nileriver23
I am currently building a surround sound system, and I am wondering which subwoofer cable to buy. The receiver is a Sony STRDG720 7.1, and the subwoofer is a PSW10 (I am planning on using the method of just putting the cable into one of the RCA inputs). The cable does not need to be any longer than 10'. Also, I am looking on buying a cheaper cable.
Thanks in advance.
Thanks in advance.
Post edited by nileriver23 on
Check into Signal Cable and welcome to Club Polk. A normal RCA run is all you need to get up and running.
http://www.signalcable.com/~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
What really works well is standard cox cable rg6 just like your cable system uses. Then at Radio shack , buy F to RCA adapters and your good to go. Excellent quality , long runs and you can run it anywhere as rg6 is in wall rated.
DanDan
Blue Jeans Cables is one of the best places to buy cables. Quality is good, Price is right, and they dont try to screw you with "Super/Ultra/Turbo/High Ends" junk.
Would this one http://www.radioshack.com/product/index.jsp?productId=3230523 or this one http://www.radioshack.com/product/index.jsp?productId=2123248 be ok?
I like the Better Cables sub cable that I got from the SVS website, and I also like AQ Black Mambo from Audio Advisor (on sale right now), which are pretty much the same as the ones I am running now
can`t really go wrong either way, and they have great pricesCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
To answer your question, yes they will work. However you might want to check out some of the other suggestions as well.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
