RTI-A9 BI-Amp reciever and external amp
DemiSlayer_A9
DemiSlayer_A9 Posts: 1
Hi i was wondering if i could bi-amp the rti-a9s my receiver running the highs and and external amp running the lows? or will the gain be missmatched with this method?
Post edited by DemiSlayer_A9 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited December 2008
    Not recommended to bi-amp with two different sources. Your going to get a unbalanced sound at different levels. Get yourself a good 2 channel amp and be done with it.
  • cfrizz
    cfrizz Posts: 13,415
    Get a nice beefy 2 channel amp & skip the biamp crap.
  • leroyjr1
    You can get a nice 2 channel amp starting at about $200. Doesn't have to be a expensive process.
  • ZOOPDOOP22
    ZOOPDOOP22 Posts: 158
    leroyjr1 wrote: »
    Do you have any recommendations? I recently bought one knowing some peoples had issues and mine was DOA. Never again cheap amps.. unless I'm completely missing something.
  • curved
    curved Posts: 664
    Get a used Adcom 545 or 555 and you'll be good to go...
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • leroyjr1
    Cheap amp should equal cheap price not cheaply made.
    Adcom makes some great amps at a reasonable prices. There's plenty floating around Craigslist, Ebay, and Audiogon.
    *Adcom 555 about $300 200watts@8 ohms.
    *Adcom 545 about $200 110watts@8 ohms.
    Other good companies
    Rotel
    Parasound
    B&K
    Emotiva
