Rear Center Channel Speaker for 6.1
I recently purchased Polk RM6700 speakers (RM2350 Satellites, RM2650 Front Center, PSW303 Sub). I want to add a rear center speaker for 6.1. What do you recommend. Can I use another RM2350 satellite?
You may get better results if you use an RM2650 Front Center
I'd probably go with the RM2350. You should be able to get it from Polk for about $119.
