RDO198's in Monitor 10s
RandyWilliamson
RandyWilliamson Posts: 178
edited December 2008 in Vintage Speakers
Was hoping to place my order for the previously suggested caps and resistors...but F1Nut mentioned the 198's would need a different inductor....was wondering if they would need anything else different before I buy my rebuild kit:
4 -12uf's
2 -34uf's or 4-17uf's (is it ok to use 33uf Dayton FF's or MP's 1%?)
plus Mill resistors.
I will buy the revising inductors and 198's together later I just don't want to bump into needing different caps or something so I'm asking now.
Also I only saw one coil/inductor where is the second (possibly smaller one)? as per the schematics for 10A.
Thanks for any advice you can lend.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Post edited by RandyWilliamson on
  • dorokusai
    dorokusai Posts: 25,576
    Why not use the correct replacement tweeter, RD-0194? Do you think you'll hear a difference?
  • Ricardo
    Ricardo Posts: 10,634
    And, is it a 10A? (You mention the 10A schematics..). Those had Peerless, and the 194/198 won't fit.
    SOPA
  • dorokusai
    I'm kinda working of his previous conversation with F1Nut. There must be a reason behind the suggestion. The 10A doesn't fall into the cookie cutter mold for tweeters. I've had Peerless, SL1000 and SL2000 10A in my travels.
  • Ricardo
    That's because you travel in weird places.
    SOPA
  • dorokusai
    Those were the guerrilla Polk days, when I would hop on any minty fresh deal in the BAWA area. I've been in more than one place and asked myself why am I in SE DC...or in Dupont Circle @ 10pm. Those days are long gone, worth the effort but not anymore.
    Warlocks has made a bunch of local runs as well. We used to tag team sellers, unknown to either of us, and run away with the spoils.
    Ahhh...those were the days.
  • RandyWilliamson
    You guys have no idea how much I truly enjoy your dialogues......truly hilarious.
    I was picking up on some good things written about the 198s vs.194s . It seems like they are similar but some tend to like the 198s a little better.
    Are you both serious about the 194/198s not fitting?
    Please tell me what type of Dayton is preffered.
    They are definite 10A's I never actually saw Peerless tweets on them but I'll take your word on it.
    Benq W5000
  • dorokusai
    If they are 10A, what is the tweeter installed now? SL1000? All you have to do is either look at it, post a picture or remove it and read the **** end of it.
  • Face
    Face Posts: 14,340
    Worst case scenario, you'll have to take a router to the cabinet.
    If you have no idea what you're doing and you're not a complete weirdo, I can help you out. :D
  • RandyWilliamson
    The backplate from these are used:
    http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-DT-100-/LS00058
    Are you serious????? I don't want to cut up on the front.
    Actually I can use the same backplate if I have to and retrofit the 194/198s to it.
    So not many here lean more on the 198s?
    Benq W5000
  • Face
    Face Posts: 14,340
    You won't be "cutting up" the front, just trimming so the magnet will fit in the cabinet. It won't be visible with 194/198's installed.
  • RandyWilliamson
    Ah ok that's not a problem.
    What about the dayton's? ff or mp 1%'s?
    So the inductor and 198's are not a popular change?
    Benq W5000
  • Face
    Face Posts: 14,340
    1% for the tweeter circuit, regular values for the low pass(woofer).
    No, it's not common in the monitor series. I have the inductors and caps needed for the conversion, but I haven't gotten around to ordering the 198's yet for my Monitor 7's.
  • RandyWilliamson
    Well for the tweeter circuit im definitely going Sonic its the lowend im going with Dayton's just don't know if either to use FF or MP or MP1%....my guess would be FF.
    Benq W5000
  • dorokusai
    Face wrote: »
    That can go both ways since some of the baffles used only fit SL1000/Peerless. Do we even know what he's using?
    Am I missing somthing?
    It isn't just the magnet...it's the frame.
  • RandyWilliamson
    Anything on the Dayton class to use for the lowend?
    Benq W5000
