Need 1 driver for Polk 11t speaker
billwagstaff
I believe the Polk part number is MW6510. Unfortunately, Polk no longer stocks them.
If anyone has any sources or pointers (or a MW6510 that they'd be willing to sell) I'd very much appreciate it.
In addition if anyone has had any luck substituting another driver in an RT 11T speaker that would be helpful as well.
Thanks in advance for any help.
--- Bill
--- Bill
Post edited by billwagstaff on
You will wan to stick with the 6510. A member or 2 may have one that they are willing to part with. Otherwise look on e-bay. The 6510 is a pretty common driver and is used in a bunch of models.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
If after a few weeks you can't find one on ebay, I've got a spare.
Few weeks okay? -
I believe this is what you're looking for?
ebay MW6510 -
billwagstaff wrote: »I believe the Polk part number is MW6510. Unfortunately, Polk no longer stocks them.
Bill,
Polk still sells the MW6510 and has plenty in stock. Call Customer Service to place your order.Political Correctness'.........defined
