Need 1 driver for Polk 11t speaker
billwagstaff
billwagstaff Posts: 1
edited December 2008 in Vintage Speakers
I believe the Polk part number is MW6510. Unfortunately, Polk no longer stocks them.
If anyone has any sources or pointers (or a MW6510 that they'd be willing to sell) I'd very much appreciate it.
In addition if anyone has had any luck substituting another driver in an RT 11T speaker that would be helpful as well.
Thanks in advance for any help.
--- Bill
Post edited by billwagstaff on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited November 2008
    You will wan to stick with the 6510. A member or 2 may have one that they are willing to part with. Otherwise look on e-bay. The 6510 is a pretty common driver and is used in a bunch of models.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • John30_30
    John30_30 Posts: 1,024
    If after a few weeks you can't find one on ebay, I've got a spare.
    Few weeks okay?
  • John30_30
    I believe this is what you're looking for?
    ebay MW6510
    F1nut Posts: 51,793
    Bill,
    Polk still sells the MW6510 and has plenty in stock. Call Customer Service to place your order.
