component cable question
jaysonbarnett
I got on optoma hd70 projector and i need to get a 50 foot component cable. I have looked online(google) and i am unsure what cable to get. The projector is only 720p so i do not need an HDMI(also i only have an component ouput on my onkyo 805) If anyone can point me to the right web site. I am looking to spend no more than 70.00 dollars but if there is a cable for a little more i am interested, or if someone has a 50 foot for sale i will be interested. thanx in advance. will this work http://www.amazon.com/dp/B000V1WUEM?smid=ALR1KZGDJ6168&tag=nextag-ce-tier4-delta-20&linkCode=asn
Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Power Conditioner:
Dvd:
Sony: BDP-350
Game Systems
WII
PS3
Post edited by jaysonbarnett on
Since it is a fairly long run for componet I would get a good cable from Bluejeanscable.com. It will cost you but if it runs anywhere near electricial outlets you do not want it picking up video noise.
You could try a cheap cable and see how it looks.Speakers: SDA-1C (most all the goodies)
I'd try monoprice.com
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023501&p_id=2776&seq=1&format=2Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
I would say monoprice as well. Since tcrossma beat me to it here is a vid only cable http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023502&p_id=2856&seq=1&format=2
do you use that cable? that is a great price i just do not want the image to look bad.thanx for the fast replyAudio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Power Conditioner:
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
Jayson, you may be lucky with the monoprice cable, I agree buying cheap for digital cables but analog will pick up noise.
I had a 16' run and tried several different cables, even monprice but could not get rid of video noise and after going to the Belden cable I has no issues with video noise.
http://bluejeanscable.com/store/component/index.htm
Just make sure Monoprice will take it back if you have noise.Speakers: SDA-1C (most all the goodies)
i just got the cable from monoprice do thanks again you guysAudio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Power Conditioner:
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
I have multiple Monoprice cables and all of them are high quality. That cable would have been my choice if I was in your position.
hey zingo are any of those 50+ feet? also how should i run it (away from outlets, speakerwire, etc)Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Power Conditioner:
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
I set up my Boss' system with a 50' component cable from Monoprice, no trouble at all. I'm currently using their 25' and 15' HDMI cables, and no issue's there either.
jaysonbarnett wrote: »do you use that cable? that is a great price i just do not want the image to look bad.thanx for the fast reply
No I do not use "that" cable, but I do use HDMI cables from Monoprice and they are great, a little stiff, but nothing that was a problem. -
You can also use 3 RG6 coax cables and out F to Rca adapters on if you are looking for something cheap.
I have coax for my projector. Best bang for the buck.
jaysonbarnett wrote: »....The projector is only 720p so i do not need an HDMI(also i only have an component ouput on my onkyo 805) ...
The 805 does have more than just component out. It has HDMI out too.
. Does the projector have HDMI in? ____________________
Pool: Atrium 60's/45's -
yes the 805 has component and HDMI but the hdmi is being used for my plasma. So since i have everything hooked up to the 805 i have the hdmi going to the tv and the component cable going to the projector. I just hope the 805 can send two signals at the same time(hdmi and component). i am mounting the screen above my tv so if i can switch between video sources. And yes the projector has an hdmi but the 805 only has one hdmi output leaving me with the component.Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Power Conditioner:
Dvd:
Sony: BDP-350
Game Systems
WII
PS3
