component cable question
jaysonbarnett
jaysonbarnett Posts: 257
I got on optoma hd70 projector and i need to get a 50 foot component cable. I have looked online(google) and i am unsure what cable to get. The projector is only 720p so i do not need an HDMI(also i only have an component ouput on my onkyo 805) If anyone can point me to the right web site. I am looking to spend no more than 70.00 dollars but if there is a cable for a little more i am interested, or if someone has a 50 foot for sale i will be interested. thanx in advance. will this work http://www.amazon.com/dp/B000V1WUEM?smid=ALR1KZGDJ6168&tag=nextag-ce-tier4-delta-20&linkCode=asn
Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power
: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3
Post edited by jaysonbarnett on
  • thsmith
    thsmith Posts: 6,082
    edited December 2008
    Since it is a fairly long run for componet I would get a good cable from Bluejeanscable.com. It will cost you but if it runs anywhere near electricial outlets you do not want it picking up video noise.
    You could try a cheap cable and see how it looks.
  • tcrossma
    tcrossma Posts: 1,301
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • apphd
    apphd Posts: 1,514
    I would say monoprice as well. Since tcrossma beat me to it here is a vid only cable http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023502&p_id=2856&seq=1&format=2
  • jaysonbarnett
    do you use that cable? that is a great price i just do not want the image to look bad.thanx for the fast reply
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Power Conditioner:
    Monster Power
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
  • thsmith
    Jayson, you may be lucky with the monoprice cable, I agree buying cheap for digital cables but analog will pick up noise.
    I had a 16' run and tried several different cables, even monprice but could not get rid of video noise and after going to the Belden cable I has no issues with video noise.
    http://bluejeanscable.com/store/component/index.htm
    Just make sure Monoprice will take it back if you have noise.
  • jaysonbarnett
    i just got the cable from monoprice do thanks again you guys
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Power Conditioner:
    Monster Power
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
  • zingo
    zingo Posts: 11,258
    I have multiple Monoprice cables and all of them are high quality. That cable would have been my choice if I was in your position.
  • jaysonbarnett
    hey zingo are any of those 50+ feet? also how should i run it (away from outlets, speakerwire, etc)
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Power Conditioner:
    Monster Power
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
  • WilliamM2
    WilliamM2 Posts: 4,804
    I set up my Boss' system with a 50' component cable from Monoprice, no trouble at all. I'm currently using their 25' and 15' HDMI cables, and no issue's there either.
  • apphd
    apphd Posts: 1,514
    No I do not use "that" cable, but I do use HDMI cables from Monoprice and they are great, a little stiff, but nothing that was a problem.
  • Logic 7
    Logic 7 Posts: 127
    You can also use 3 RG6 coax cables and out F to Rca adapters on if you are looking for something cheap.
  • wallstreet
    wallstreet Posts: 1,405
    I have coax for my projector. Best bang for the buck.
  • mmadden28
    mmadden28 Posts: 4,283
    ....The projector is only 720p so i do not need an HDMI(also i only have an component ouput on my onkyo 805) ...
    The 805 does have more than just component out. It has HDMI out too.
    :confused:. Does the projector have HDMI in?
    ____________________
    Pool: Atrium 60's/45's
  • jaysonbarnett
    yes the 805 has component and HDMI but the hdmi is being used for my plasma. So since i have everything hooked up to the 805 i have the hdmi going to the tv and the component cable going to the projector. I just hope the 805 can send two signals at the same time(hdmi and component). i am mounting the screen above my tv so if i can switch between video sources. And yes the projector has an hdmi but the 805 only has one hdmi output leaving me with the component.
    Audio:
    Onkyo :tx-sr805
    Polk: rti8's
    Polk: rti4's
    Polk: fxi3's
    Polk: csi'3
    Velodyne: VRP 1200
    Epik: Caliber
    Video:
    Power Conditioner:
    Monster Power
    Dvd:
    Sony: BDP-350
    Game Systems
    WII
    PS3
