Which would you do ...
wizzy
wizzy Posts: 867
edited December 2008 in 2 Channel Audio
If you have a H/K receiver (3480) and RTi10's
Would you either:
a) Chuck the RTi10's in the trash, keep the HK, and buy LSi9's
b) Chuck the HK receiver in the trash, keep the RTi10's, buy an Emotiva XPA-2
Post edited by wizzy on
  • WilliamM2
    WilliamM2 Posts: 4,808
    Always go for better speakers.
  • Conradicles
    Conradicles Posts: 6,371
    Keep the HK-3480 and add some SDA's.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Throw the 10's in the garbage. Then give me your address.
  • thsmith
    thsmith Posts: 6,082
    wizzy wrote: »
    Would you either:
    If your H/K has pre-outs throw some power to those 10s then decide. Even if you went with SDAs you will need power. A friend has 10s and they really woke up when he put some power to them.
  • Hawkeye
    Hawkeye Posts: 1,313
    HT or 2 Channel? If HT more power, if 2 channel, better sounding speakers (in your opinion) have always provided me with the most significant and obvious improvement to me.
    Won't you need the H/K if you get an XPA2?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • nikolas812
    nikolas812 Posts: 2,915
    Get the Lsi9's. You won't be disappointed.
    I have the HK3490 which I think is just a newer model than yours. Driving a pair of Lsi9's and it sounds fabulous!!
    People say receivers don't have enough power to push LSi's. Well. This one does IMO. I have had my LSi9's powered with separates and the HK defiantly holds its own in the power department......
    Nick
  • wizzy
    wizzy Posts: 867
    Hawkeye wrote: »
    HT or 2 Channel?
    2-channel, thus the posting here in 2-channel-audio board.
    I have some options for pre-amp ... or the H/K will work too.
  • wizzy
    wizzy Posts: 867
    nikolas812 wrote: »
    Hey, I was just in Indiana a month ago. Evansville for a few days, and a day in Bloomington visiting IU.
  • Early B.
    Early B. Posts: 7,900
    If you're into 2-channel, then both the H/K and 10's need to go. But if you can't do both at the same time, go with option b and get rid of the 10's ASAP.
    "God grooves with tubes."
  • gdb
    gdb Posts: 6,012
    Wizzy, if you do get the Emotiva please post a reveiw on it after you've run it for a while.:)
  • wizzy
    wizzy Posts: 867
  • ben62670
    ben62670 Posts: 15,969
    A, and get LSI's, or SDA's;)
    Ben
  • Face
    Face Posts: 14,340
    I would opt for LSi's also.
  • fatchowmein
    fatchowmein Posts: 2,637
    I'm running a 3485 and Lsi9's in a small bedroom/office (10x10). I vote for the 9's.
