Which would you do ...
wizzy
If you have a H/K receiver (3480) and RTi10's
Would you either:
a) Chuck the RTi10's in the trash, keep the HK, and buy LSi9's
b) Chuck the HK receiver in the trash, keep the RTi10's, buy an Emotiva XPA-2
Would you either:
Post edited by wizzy on
Always go for better speakers.
Keep the HK-3480 and add some SDA's.
Throw the 10's in the garbage. Then give me your address.
Would you either:
If your H/K has pre-outs throw some power to those 10s then decide. Even if you went with SDAs you will need power. A friend has 10s and they really woke up when he put some power to them.Speakers: SDA-1C (most all the goodies)
HT or 2 Channel? If HT more power, if 2 channel, better sounding speakers (in your opinion) have always provided me with the most significant and obvious improvement to me.
Won't you need the H/K if you get an XPA2?
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Get the Lsi9's. You won't be disappointed.
I have the HK3490 which I think is just a newer model than yours. Driving a pair of Lsi9's and it sounds fabulous!!
People say receivers don't have enough power to push LSi's. Well. This one does IMO. I have had my LSi9's powered with separates and the HK defiantly holds its own in the power department......
Nick -
HT or 2 Channel?
2-channel, thus the posting here in 2-channel-audio board.
I have some options for pre-amp ... or the H/K will work too. -
nikolas812 wrote: »Get the Lsi9's. You won't be disappointed.
Hey, I was just in Indiana a month ago. Evansville for a few days, and a day in Bloomington visiting IU. -
If you're into 2-channel, then both the H/K and 10's need to go. But if you can't do both at the same time, go with option b and get rid of the 10's ASAP.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Wizzy, if you do get the Emotiva please post a reveiw on it after you've run it for a while.:)
A, and get LSI's, or SDA's;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I would opt for LSi's also."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'm running a 3485 and Lsi9's in a small bedroom/office (10x10). I vote for the 9's.
