Simple Bi-amp fro Rti A9s
Que2008
I have a pair of Rti A9s that I am thinking about Bi-amping. I am currently running them off of a HK 635 @ 75W rms. I also have a CSi A6 center on the HK. I just purchased a HK PA 2000 amp that runs 100W rms x2. From some of the reviews I have read about the PA 2000, It may run closer to 150W rms.
I am trying to decide if I should run the Rti A9 highs off of the receiver and the lows off of the PA 2000 or should I just run the A9s full range from the 2000. Does anyone have any ideas about which would sound better? What about the center channel? Will the receiver's power still give me a good sound stage?
Jon
Jon
Current setup:
Sony KDL-52W4100 LCD TV
HK AVR-635 receiver pre
Emotiva XPA-5 Amp
PS3
BFD
Oppo DV-983H
Panamax MAX 5400-PM Voltage Regulator
Polk RTi A9 mains
Polk CSi A6 center
Polk FXi A6 surrounds
SVS PB12-Ultra/2 sub
DishNetwork ViP 622 SAT RCVR
Emotiva XPA-5 Amp
PS3
BFD
Oppo DV-983H
Polk RTi A9 mains
Polk CSi A6 center
Post edited by Que2008 on
One more thing, What I really want to accomplish is more upper bass punch.Current setup:
Emotiva XPA-5 Amp
PS3
BFD
Oppo DV-983H
Polk RTi A9 mains
Polk CSi A6 center
DishNetwork ViP 622 SAT RCVR -
More bass punch?
Use the new amp for the woofer and bi-amp using an electronic crossover. I don't know if your receiver will accommodate you for the crossover.
p.s. Can you bi-amp those speakers, or bi-wire only? You need to find a way to bypass the speakers internal crossover to get the advantage of bi-amping. -
When I tried it with my RTI A9's I didn't notice any difference bi amping them. I also was giving them 200watts each (Adcom 555II). IMO I wouldn't bi amp off two different sources.
I have decided to just run the PA 2000 on my RtiA9s full range for now. I have been looking into purchasing a separate amp for the theater and taking the PA 2000 out of the picture for now. Does anyone have any experience with Emotiva's MPS-2 or XPA-5 amps? I could use the AVR 635 as a preamp.
JonCurrent setup:
Emotiva XPA-5 Amp
PS3
BFD
Oppo DV-983H
Polk RTi A9 mains
Polk CSi A6 center
Welcome to Club Polk!! :cool:
I'm using my Onk 805 as a pre and the Emo XPA-5 to drive RTi12's (predecessor to the RTiA9's). I am very happy with the results.
I'm also using a subwoofer with the AVR crossover set to 80Hz. Since the XPA-5 doesn't have to handle anything below 80Hz, it can provide more power/headroom to the speakers above 80Hz.
And yes you can bi-amp or bi-wire them, you only need to remove the jumper between the upper and lower binding posts. No need for an external crossover.
One concern when bi-amping with different model amps is the gain factor. If they are different, when you change the volume on the AVR/Pre, the apparent volume increase may not be the same from each amp, resulting in either the highs or lows increasing in volume faster than the other (if you follow that).____________________
Pool: Atrium 60's/45's -
I have decided not to bi-amp my Rti A9s because, from what I have read, you need to disable the internal crossovers and use an external crossover with two amps. I am not willing to dig into these speakers just yet. They sound great on my AVR, but I have the upgrade bug and may buy a XPA-5 in the next few weeks. maybe I can talk my wife into it.
On a side note, does anyone else have the HK 635, and if so, have you ever noticed the center channel fading in and out?Current setup:
Emotiva XPA-5 Amp
PS3
BFD
Oppo DV-983H
Polk RTi A9 mains
Polk CSi A6 center
External crossover??? Just remove the jumper plate. In fact, try this: remove the jumper and hook up the amp to the bottom side. Do you hear any sound coming from the tweeter...Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
