Sub-Woofer Placement - See picture
singitloud
Okay, it took me about an hour to make this picture, so I hope it helps.
This is my setup and I am wanting to know if the sub-woofer placement is a good placement?
I want to keep it near the TV since I am running the wiring through the sub* and then up through the wall to the attic.
*I used the POLK recommended sub-wiring with my original RM-6600 series with much satisfaction. Can I assume it will work just as well, if not better, with this setup?
Dwaine
Dwaine
Sing... Worship... Live the Life
Post edited by singitloud on
I too have my sub off to the left of my left front channel only because I have a 60" DLP on an entertainment center/stand and can't put it where it "belongs" which is directly in front of you under the TV. I have attached a link to the THX speaker setup schematic that details where each speaker "should be". However, the most important thing to remember is what sounds best to you, move it around, face it towards the wall etc, until you are most pleased with the performance. If you only have one, I think the general consensus here would be to stick it in the corner pretty much where you have it, or in the opposite corner, but like I said experiment and see where it sounds best to you.
http://www.thx.com/home/setup/speakers/sub.htmlHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
What do you mean "Polk recom. sub-wiring"? Did it come with your older sub? If so, it probably is not good enough. Try signal cable or blue jeans cable. As for placement, you need to experiment with different positions and go from there.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Now see, that is very interesting indeed.
My Credenza is such that I can add each section. I used to have all four, which gave me the sub under the TV (just off-center to the right) and the center speaker under the TV (just off-center to the left). With my new room being smaller, my wife wants me to use only three sections. This gives me a section centered under the TV which is where I am planning to put my new CS1 (I bought the CS2, but it is 2.5" too wide :mad:) - Thus my sub dilemma.
If I am unhappy with the sub off to the side, I may go back to the four sections.
Dwainewutadumsn23 wrote: »I too have my sub off to the left of my left front channel only because I have a 60" DLP on an entertainment center/stand and can't put it where it "belongs" which is directly in front of you under the TV. I have attached a link to the THX speaker setup schematic that details where each speaker "should be". However, the most important thing to remember is what sounds best to you, move it around, face it towards the wall etc, until you are most pleased with the performance. If you only have one, I think the general consensus here would be to stick it in the corner pretty much where you have it, or in the opposite corner, but like I said experiment and see where it sounds best to you.
http://www.thx.com/home/setup/speakers/sub.htmlSing... Worship... Live the Life -
The POLK recommended wiring for your sub is detailed here.
Okay, I went and looked for the article and was unable to find it anymore...
I wire my speakers in-line with my sub rather than using the LFE channel. Honestly, in the past it gave me much better control over my system crossover etc. - I think I will email POLK and ask what they recommend since I am using larger front speakers now (6.5" drivers vs. my old 3.5" drivers).
DwaineWhat do you mean "Polk recom. sub-wiring"? Did it come with your older sub? If so, it probably is not good enough. Try signal cable or blue jeans cable. As for placement, you need to experiment with different positions and go from there.Sing... Worship... Live the Life
