VMPS Larger "Tallboy" Subwoofer
Conradicles
Conradicles Posts: 6,345
Time to part with this big monster. I just do not have the room in my small house.
More pics can be found on e-bay. You can find me there as talldude777.
I will sell it a bit cheaper to Club Polk members...$250
Local pick-up is the best option, but I can ship if you are really interested. I have the perfect crate at work to pack and ship LTL.
PM me for a Shipping Quote.
2 blemishes in the last 2 pics. Other than that it looks fantastic!
Let me know if you have any questions.
Post edited by Conradicles on
  • McLoki
    McLoki Posts: 5,231
    edited November 2008
    Any "megawoofer" upgrades? Any rough ideas for physical measurements or weight?
  • Conradicles
    The previous owner said it had the Megawoofer upgrade, but I do not know for sure.
    Dims = 39" Tall x 21.5" Wide x 17" Deep
    In other words...this thing is huge!
    VR3 Posts: 29,448
    Those are not megawoofers.
    Megawoofers look like this --
    And the Larger/Tall Boy is a POWERHOUSE, an easy 100-110+ DB at 20hz, no issues
  • Conradicles
    Thanks for the clarification Sid the Kid. My VMPS does not have the megawoofer upgrade.
    It is a POWERHOUSE...my back can testify!
    treitz3 Posts: 20,019
    Does this have the passive woofer as well?
    VR3 Posts: 29,448
    It is the same subwoofer as what you have Tom
    You would have to upgrade the Woofs and PR though to match them
    Where is the passive? Located on the bottom I take it......
  • Conradicles
    Yes. 15" Passive. You can't see it because it is hidden inside and fires out of the slot on the bottom front. You can feel it if you stick your hand in the slot, or you can unscrew the bottom wooden base of the box.
    I heard there is a way you can tune the passive to a certain Hz, but I do not know how to do that.
  • Early B.
    Early B. Posts: 7,900
    This is a killer sub. I had been looking for one of these for a while until I ran across a local VMPS 215 sub which is the baby brother to this one. Mine only has a 15" driver and 15" passive.:( Just add an amp and you're done. There's no better way to get very high quality, low cost subwooferage than VMPS.
    "God grooves with tubes."
  • Conradicles
    I forgot to mention this is rated @ 4 ohms and also has a passive crossover. I think the crossover is around 85 Hz.
    However, I heard they sound better if you use an electronic crossover.
  • McLoki
    McLoki Posts: 5,231
    Is there an LFE input on it? (i.e. - can you hook up to another set of terminals and bypass the internal crossover?)
  • Conradicles
    No. It has two sets of speakers connections for each sub. (total of 4)
    The 12" woofer has gold plated speaker inputs and regular high pass outputs.
    The 15" woofer has gold plated speaker inputs and regular high pass outputs.
    Hope that makes sense. It is technically a "stereo" sub in that you feed it a left and right channel.
  • hoosier21
    hoosier21 Posts: 4,418
    McLoki wrote: »
    it is a passive subwoofer
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    Or if it's like mine, you can rewire it into a mono sub with 2 active and 1 passive. Yes, an active x-over does improve the performance of this sub and I can also attest to the sub's sonic qualities. I had an audio event recently and had the lowboy or regular version of this sub hooked up and the most frequently heard comment was "that's the best sub integration that I've ever heard, I can't even tell where it's coming from. How did you do it?". Of course the SMS-1 had a lot to do with it but no matter what lower frequency was needed and at what volume it was required to do....it delivered it accurately without even breaking a sweat.
  • concealer404
    concealer404 Posts: 7,440
    Ballpark shipping quote to 46143? :)
  • gwh
    gwh Posts: 1,451
    I'm assuming this would smoke my 25-31 CS ???
    Shipping quote to 73505 please.
    G
    HT:
    Martin Logan Motion 40
    Martin Logan Motion 50XT
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Def Tech Reference Sub
    Yamaha RX-A3070
    Signal Cable speaker wires & interconnects.
  • Conradicles
    PM shipping quotes sent to concealer404 and gwh. Thanks.
  • Conradicles
  • gtu2004
    gtu2004 Posts: 620
    ir eally never heard of this sub but how does this compare to say, SVS PB10?
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • Conradicles
    gtu2004 wrote: »
    I have never heard that SVS, so I can not compare. Maybe some other guys here can comment on that.
    I sure can't but I will say this.......properly powered, this is all the sub I'll EVER need.
  • SolidSqual
    SolidSqual Posts: 5,218
    gtu2004 wrote: »
    I owned the PB10. It sucks. Looking at the specs alone and hearing other VMPS subs, the Tallboy would blow the SVS away.
    SVS makes a mediocre sub that's good for breaking bones. The Tallboy is made for music and finesse. That being said, it could at least fracture a pelvis and bruise some ribs.
  • gtu2004
    gtu2004 Posts: 620
    this one is passive though right? might need to invest in separate amp?
  • Conradicles
    Yes, passive. No amp built into this one.
  • NotaSuv
    NotaSuv Posts: 3,871
  • Conradicles
    Sale pending to NotaSuv...
  • NotaSuv
    $$$$$ sent
  • Early B.
    Congrats. You're gonna love it. Let me know if you need a primer on pinching putty. Trust me, it works wonders.
  • Conradicles
    Now that it is sold...I know I am really going to miss it...but I need to find some more SDA's.
    VR3 Posts: 29,448
    I miss my stereo largers sometime... :(
    But, when you are capable of reproducing 120db at 20hz in a 10.5x10.5x8 room, you gotta move on eventually! :)
    Congrats on the subpurchase, you will not be unhappy!
