VMPS Larger "Tallboy" Subwoofer
Conradicles
Time to part with this big monster. I just do not have the room in my small house.
More pics can be found on e-bay. You can find me there as talldude777.
I will sell it a bit cheaper to Club Polk members...$250
Local pick-up is the best option, but I can ship if you are really interested. I have the perfect crate at work to pack and ship LTL.
PM me for a Shipping Quote.
2 blemishes in the last 2 pics. Other than that it looks fantastic!
Let me know if you have any questions.
Post edited by Conradicles on
Any "megawoofer" upgrades? Any rough ideas for physical measurements or weight?Mains.............Polk LSi15 (Cherry)
The previous owner said it had the Megawoofer upgrade, but I do not know for sure.
Dims = 39" Tall x 21.5" Wide x 17" Deep
In other words...this thing is huge! -
Those are not megawoofers.
Megawoofers look like this --
And the Larger/Tall Boy is a POWERHOUSE, an easy 100-110+ DB at 20hz, no issues- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks for the clarification Sid the Kid. My VMPS does not have the megawoofer upgrade.
It is a POWERHOUSE...my back can testify! -
Does this have the passive woofer as well?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
It is the same subwoofer as what you have Tom
You would have to upgrade the Woofs and PR though to match them- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Where is the passive? Located on the bottom I take it......~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Yes. 15" Passive. You can't see it because it is hidden inside and fires out of the slot on the bottom front. You can feel it if you stick your hand in the slot, or you can unscrew the bottom wooden base of the box.
I heard there is a way you can tune the passive to a certain Hz, but I do not know how to do that. -
This is a killer sub. I had been looking for one of these for a while until I ran across a local VMPS 215 sub which is the baby brother to this one. Mine only has a 15" driver and 15" passive.:( Just add an amp and you're done. There's no better way to get very high quality, low cost subwooferage than VMPS.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I forgot to mention this is rated @ 4 ohms and also has a passive crossover. I think the crossover is around 85 Hz.
However, I heard they sound better if you use an electronic crossover. -
Is there an LFE input on it? (i.e. - can you hook up to another set of terminals and bypass the internal crossover?)Mains.............Polk LSi15 (Cherry)
No. It has two sets of speakers connections for each sub. (total of 4)
The 12" woofer has gold plated speaker inputs and regular high pass outputs.
The 15" woofer has gold plated speaker inputs and regular high pass outputs.
Hope that makes sense. It is technically a "stereo" sub in that you feed it a left and right channel. -
it is a passive subwooferDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Conradicles wrote: »No. It has two sets of speakers connections for each sub. (total of 4)
Hope that makes sense. It is technically a "stereo" sub in that you feed it a left and right channel.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Ballpark shipping quote to 46143?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I'm assuming this would smoke my 25-31 CS ???
Shipping quote to 73505 please.
GHT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
PM shipping quotes sent to concealer404 and gwh. Thanks.
bump
ir eally never heard of this sub but how does this compare to say, SVS PB10?Onkyo 805, RtiA5s, Csi5, Rti6s
I have never heard that SVS, so I can not compare. Maybe some other guys here can comment on that. -
I sure can't but I will say this.......properly powered, this is all the sub I'll EVER need.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I owned the PB10. It sucks. Looking at the specs alone and hearing other VMPS subs, the Tallboy would blow the SVS away.
SVS makes a mediocre sub that's good for breaking bones. The Tallboy is made for music and finesse. That being said, it could at least fracture a pelvis and bruise some ribs. -
this one is passive though right? might need to invest in separate amp?Onkyo 805, RtiA5s, Csi5, Rti6s
Yes, passive. No amp built into this one.
PM sent
Sale pending to NotaSuv...
$$$$$ sent
Thanks -
Congrats. You're gonna love it. Let me know if you need a primer on pinching putty. Trust me, it works wonders.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Now that it is sold...I know I am really going to miss it...but I need to find some more SDA's.
I miss my stereo largers sometime...
But, when you are capable of reproducing 120db at 20hz in a 10.5x10.5x8 room, you gotta move on eventually!
Congrats on the subpurchase, you will not be unhappy!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
