Need center for LS90's - CSi A6 or cs350ls?
timlitton
timlitton Posts: 289
edited December 2008 in Speakers
I've had a pair of LS90's for about 10 years now. I absolutely love them. I want to upgrade my center channel from a junky cs100 (poor *-bay decision making skills a few years ago).
I've been on the hunt for a cs1000p for a few years and unfortunately got outbid on *-bay just yesterday. The price went from $205 to $455 in the final seconds. They come up so rarely, I figured I'd stop waiting and take the plunge on something else.
I've read such good things about the cs350's. Polk's website says the CSi A6's will match, but which would be the best? Or are there others that would be better?
Any advice would be appreciated.
Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3
Post edited by timlitton on
  • mantis
    mantis Posts: 17,563
    edited November 2008
    The older 350 is a perfect patch. it's what was around back then. The new series will not match the same. Sonic changes over the years.
    So here is what you do, send me your Ls90's( I love em) and I'll steer you to Tweeter to get a full front array. They are going out of business and you can score some new Polks at a great price.
    So what do you say???
    Dan
  • timlitton
    Thanks for the reply mantis.
    But... I'm afraid I'm not yet eligible to do transactions here. I'm bound by the rules you know. You on the other hand, have more than enough posts to allow you to send ME a 350.
    I'll even kick in a couple bucks for shipping.
    Amp: Rotel RMB-1075
  • adam2434
    adam2434 Posts: 995
    I also have LS90s and have owned the CS350 and CS400i. While the CS400i is from a newer/different speaker series, I actually found it to be a better match than the CS350, from an upper frequencies standpoint. The CS400 and CS400i use a very similar trilaminate tweeter to what is in the LS90 and CS350. I am currently using the CS400i.
    So, you may want to also keep an eye out for a CS400 or CS400i.
    Oh, and welcome to the forum!
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • DollarDave
    DollarDave Posts: 2,575
    adam2434 wrote: »
    I have had the same experience as adam2434 - I strongly prefer the CS400 with my LS-90s. I tried a CS200, then a CS350, then a CS400. Hands down he 400 rules. I may even get/trade for a 400i to replace my CSI-40 downstairs.
  • mantis
    DaveMuell wrote: »
    So when things go from left to right, you don't get any change? Synergy is key here? I'm just interested as I have over the years owned and Installed all of the above products. My findings with the 2 different years little different.
    I found the 350 to be very good when properly setup, I know good luck finding one and I'm sure the 400 is easier to find, so my only question is why it works better? Not just a question for you but anyone else who has experience with this exact setup,
    Dan
    Dan
  • timlitton
    Thanks for the input adam2434 and DaveMuell. I'll have to take a look for the cs400's too. I found myself quite lucky that within 20 minutes of posting this thread, I found a cs350 on ebay and also on craigslist (which was for $100).
    For the cs400 proponents, I'm also curious what makes it better or worse in your experience. I dislike the cs100 for multiple reasons but the biggest reason is the lack of low end and presence. With the LS90's there's a incredibly noticeable difference in sound as it pans across to the small cs100. How would you describe the overall performance of the cs400 sound-wise in relation to the cs350?
    Amp: Rotel RMB-1075
  • Jeff Beaird
    Jeff Beaird Posts: 217
    I also thought the CS350 was lacking clarity, real boomy..!
    I was so disappointed in it I sold it on the Forum for $100. I would like to try a CS400... to replace the Monitor 5jr which I am currently using
    Thanks, Jeff...
  • mantis
    I think that thats exactly the problem here, Lets go back to basics.
    For any home theater front 3 or I will call it L C R meaning Left Center Right have to match. This is critical. If your watching a movie, you don't want one speaker to sound different then another. The correct matching center should always go with the main speakers. You should not mix and match. The sonic signature has to match. If the center is better then the mains or visa versa then you will not have synergy. This will be distracting and you will not get a good home theater experience.
    If you found a 350 in good shape , I suggest you buy it now. I don't think using the cs400 or cs400i is a good choice. It seems others have had good luck with this but they must have a reason to do this. I'm not a fan of doing this at all. There are other factors that come into play that can cause a speaker not to sound good. If it's a matching speaker and you don't like it, then you need to rethink your main speakers and buy a entire front array that all matches. Remember my goal is to build a system, anyones system with complete synergy. No exceptions unless no other option is available.
    Dan
  • DollarDave
    mantis wrote: »
    Dan
    I agree synergy is key, and the CS-350 pretty much sucked in my opinion even when "properly setup" via calibration. The CS-400 has a deeper, wider, and more accurate reproduction of sound. That simple. The 350 kicked a#$ on the other models that I have tried. But, the 400 remains the standard.
  • Jeff Beaird
    I think I would rather sell my LS90's than buy another CS350...
    I looked around here(local) for many years to find these. I believe in synergy. Obviosly I don't have that w/5jr Center.
    Thanks, Jeff...
  • Ron Temple
    Ron Temple Posts: 3,212
    adam2434 wrote: »
    Agree, I thought the tweeters of the LS50s I tried matched very well with the CS400i.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • adam2434
    adam2434 Posts: 995
    I got into more depth on the CS350 vs CS400i question in this thread:
    http://www.polkaudio.com/forums/showthread.php?t=32790&highlight=cs350+crossover+mod
    Post 15 is a good recap.
    Basically, my ears told me that the 350 had a much softer top end, compared to my LS90's. While experimenting, I found that my Pioneer Elite's auto EQ (which I don't use for listening) corroborated this and wanted to boost the highest band +5dB for the 350, while leaving the LS90's flat at 0dB. The auto EQ also set the 400i to 0dB for the highest band.
    I think the 350 is a great center, but I still feel that the 400i is a better match than the 350 I had.
  • Jeff Beaird
    Ben has a good recap option also... a day late and a dollar short for me but might help other CS350 owners. Here's the thread...
    http://www.polkaudio.com/forums/showthread.php?t=73915&highlight=cs350
    Thanks, Jeff...
  • timlitton
    Interesting. I'm obviously new to the forums but have already read a number of threads about modding XO's and tweeters. I'm always left wondering if it's worth the effort or if I should just buy something I like out-of-the box.
    It's kinda the same reason I bought a BMW instead of a car that had to be modded. That is, until I saw a Vishnu piggyback kit that adds 100+ HP to a twin turbo 335 for about $1200. Sorry about the off-topic.
    Amp: Rotel RMB-1075
  • timlitton
    I just saw a listing for a csi40. What's the scoop between the cs400i and the CSi40? Any opinions on which is better?
    Amp: Rotel RMB-1075
  • Ron Temple
    Haven't heard the CSi40, but it's probably closer to the CSi5 than the CS400i. From experience the silver dome tri-lams are a dead match with the LS.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • ohskigod
    ohskigod Posts: 6,505
    just my .02
    Had the LS90's for a while and used them with the cs350. for me, it sounded fantastic. I know some say they didnt like it and went with the 400 but I had no issues that made me do the change.
    I ran the ls90 and cs350 set up (with seperate amplification all around) for awhile with great results until I got my LSi set up. while I like the LSi set up bettr, it isnt by much. That LS/CS setup kicked **** for years in my house, with the CS350 being a big part of it.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • timlitton
    Thank you everyone for the advice.
    ohskigod, I appreciate the info. I've debated selling off my LS90's in favor of the new LSi line but I may wait until I can find a good second-hand price down the road a few years. I can't afford all new speakers and a reliable 4 ohm amp all at once, and I'm encouraged by your direct comparison.
    Amp: Rotel RMB-1075
