Tone controls
b_dick
My receiver (H/K 3485) has conventional tone controls, knobs for bass and treble. Can someone tell me what frequencies are affected by each of these controls?
Post edited by b_dick on
It should be in the manual. IIRC they are at 100hz, and 10,000hz.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I did look in the manual, Ben (BTW I hope you are healing well); I didn't find it there. Those figures you recall seem extreme to me. That would leave ten octaves in the middle unaffected. 10,000 Hz is more than an octave above the highest key on a piano. 100 Hz is about 2 octaves above the lowest key.
Anybody else? -
I think that's fairly universal. The Luxman pre's tone controls effect the same frequencies, +/- 10dbs at 100 and 10K.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »I think that's fairly universal. The Luxman pre's tone controls effect the same frequencies, +/- 10dbs at 100 and 10K.
Thanks Ron. The +/- 10 dB figure is in my manual, but not the frequencies. I'm thinking that the effect probably doesn't come on abruptly as you go up or down the sound spectrum but probably "ramps up", instead. There would then be a frequency where the ramp starts (two actually, for the two controls.) That would leave some frequencies, beyond where the ramp starts, unaffected. There must be a range of frequencies in the middle above the portion affected by the bass control and below the portion affected by the treble control. Or perhaps the two ramps begin at the same frequency and there is no part of the spectrum unaffected. Or maybe the bass ramp starts at the very top and the treble ramp starts at the very bottom. That is what I am trying to learn. -
My Onkya A-9555 manual says + 10dB, -10dB, 100 HZ (BASS) and +10dB, -10dB, 20kHz (TREBLE)
20khzMy Onkya A-9555 manual says + 10dB, -10dB, 100 HZ (BASS) and +10dB, -10dB, 20kHz (TREBLE)
...that's modulating a mosquito buzz on helium.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Most of the figures I come across are so many db’s of gain/cut (usualy 10dB+/- sometimes 6+/-...) at 100hz (bass) and 10khz (treble) some frequencies are slightly different but not a great deal say 80hz on the bass and 12khz on treble.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
