RM 6750 Offical Owners Thread
marcuslaw
marcuslaw Posts: 2
edited November 2008 in Speakers
I didn't see one, so I'm going to go ahead and start it now.
Introducing a complete home theater audio solution for people who crave true cinema excitement without breaking the bank.—the RM6750. The integrated Power Port Bass Vent designed right onto the back of the compact Satellite & Center Channel speakers-the same technology used in full-sized Polk Audio speakers-improves lower midrange response and all-important sub/sat blending, taking the RM6750 beyond the performance realm of any other sub/sat system in this price range. This integrated design reveals midrange with no “hole” in the frequencies between the sats and the sub, for male vocals that are rich and full-not thin and weak like other sub/sat systems. The RM6750 comes with its own subwoofer module, an 8 inch long throw driver and high current power amplifier for real ground-shaking bass thrills.
The RM6750 features:
Satellites use a 3-1/4 inch (8.25cm) Polymer composite cone driver: lightweight and efficient, for clear, distortion-free midrange. The center speaker uses two of the same high quality drivers for even greater output capability.
Integrated baffle and grille design allows maximum sound dispersion with minimum diffraction for superior imaging and room-filling sound. Everyone in the room hears clear, well-balanced sound.
High performance 1/2 inch (12mm) Silk Dome Tweeters for superior imaging and smooth highs.
Mineral-filled Polypropylene Enclosures are non-resonant for great looks and natural sound.
Satellites available in either Black or Titanium finish (Subwoofer is always easy-to-hide black)
Individual satellites available to accommodate 6.1 or 7.1 channel systems.
Integrated Keyhole Slot wall mounting brackets (two Keyhole Slots on Center Channel Speaker) allow for easy wall mounting, with no extra brackets or wall mounts to buy; threaded inserts accept popular articulating brackets (sold separately).
The Subwoofer, in a compact ported enclosure, features an 8-inch Long-Throw Dynamic Balance Poly Composite Driver for longer driver excursion and better linearity, resulting in big, musical bass.
Built-in Subwoofer power amp (50 Watts Continuous/100 Watts Dynamic Power) with active crossover offers the control you need for real home theater thrills and big, musical, accurate bass. Features variable Low-Pass Filter and Volume (level) controls, as well as Phase Switching Toggle, and signal-sensing Auto ON/OFF, for even more control and convenience.
Polk does 6.1 and 7.1!
Building an EX or ES surround sound system for 6.1 or 7.1 (or more) speakers? You can get RM6750 speakers in Single Center Channel (RM6752) and Single Satellite (RM6751) packs to fill out the speaker requirements of more-than-5.1 multi-channel systems. RM6750 single satellites are available in White, Titanium and Black finishes, centers are available in Black and Titanium. Ask your Polk retailer to special order them for you or call Polk Customer Service 800-377-7655.
Post edited by marcuslaw on
  • McLoki
    McLoki Posts: 5,231
    Welcome to Club Polk.
    I believe these are a newer model of the RM6600 speakers that I used to have. Great speakers for the size and price. Have any specific questions?
    Michael
  • marcuslaw
    marcuslaw Posts: 2
    Well, actually, yes. Two things. First, I saw a post somewhere in this Forum stating that the sub isn't very good. Not being an audiophile, I'm not sure why since it seems to work just fine under demanding conditions like high volume during a DTS MA playback. Secondly, does Polk recommend a particular brand of speaker stand for one of the 6750's satellite speakers?
  • McLoki
    McLoki Posts: 5,231
    For my 6600's - I used a polk PSW-350 subwoofer.
    Prior to the MicroPro series of subs, I have not been a big fan of polk subs for home theater use. (I always thought they were rather musical for the price paid, they just do not dig really deep (to 20hz or lower) for home theater. At one time they were as good as anything else on the market, but with the new internet direct companies (eD, Epik, SVS, HSU, Outlaw, etc.) the market has changed. Polks new MicroPro subs are really nice though. I cannot say if that is the reason for others to say the sub you have is not very good or not - but that is why I would have looked elsewhere.
    Also keep in mind that for the price you get many polk subs (under $500) there is still not alot of competition and for that price, they are not that bad....
    Regarding the speaker stands - are you looking for stands or brackets (to mount to the wall). There is a screw hole in the back of the speaker. I used wall mounts and the standard mounts that they sell at best buy and circuit city in singles and 5 packs worked just fine for me. The way I made sure mine would fit was I just took one speaker to ACE hardware. Found a screw that would fit into the back of the speaker then spent about .$0.07 on a nut to fit that screw. Then I just took that nut with me to the local stores and purchased a mount that fit it....
    You can always call polk customer service (a toll free number) if you have questions or feel free to post here and someone will jump in and help you out.
    Again, welcome to Club Polk,
    Michael
