Noob subwoofer psw 111
Buckeye5
I have a 5.1 setup with a complete line of polk tsi series, floorspeakers tsi 300, rear surround tsi 200, center channel & the subwoofer 111. This is all connected to a yamaha rx-v663 receiver. The problem is the subwoofer doesn't produce any noticeable bass sound. I have it hooked up with an LFE cord, set all the speakers to small and the bass to subwoofer only. The sub is so quiet even when I have my ear to it.
Post edited by Buckeye5 on
What is your frequency crossover set at?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
80 on the receiver and all the way I think 140 on the sub.
Okay well thats not the problem have you checked your connections and also look at your audio output what that is set on. Try switching to different audio outputs like from stereo to dolby and all the others see if that helps.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Can you hear anything at all out of the sub? A friend called me after I sold him my old Onkyo HTIB saying that the sub wasn't working, eventhough it was fine a few days before when I pulled it all down and stored it. Does your sub have a "power light" or a light that is more than likely red or yellow in standby/off mode and green or blue when on. If so, what color is it? Check the connection to your reciever, there is normally two purple connections in the back and alot of people hook up the sub cord to the wrong input on the sub. Make sure it is plugged into the purple input on the back of the reciever that is labeled subwoofer pre-out. My friend had it hooked up to the wrong one, switched it and it worked just fine.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I can barely hear bass coming from the sub when I have my ear to it. There is a green light on in the back and the sub is connected with the lfe cord to the subpreout.
Do you hear your Sub in general? Try turning down all of your speakers and then seeing if you hear the bass incase your floor's are making it feel like your sub is on.
Is it definitely on though? Just quiet? That's what I'm trying to have you figure out. It could be the amplifier in it is going out.
Music [2.2]
Speakers: polkaudio RTi12
Future Speakers: DIY Fusion-15 Sentinel's
Subwoofer: DIY Dual LAB15's
Subwoofer Amp: Behringer iNUKE NU6000DSP
Preamp: Emotiva XSP-1
Amp: Emotiva XPA-2
CD Player: Emotiva EMC-3
DAC: Emotiva XDA-2 Gen2
Turntable: Denon DP300F w/ Ortofon 2M Red
Tuner: Rotel RT-1080
Power: Monster HTS 5100 MKII
Amp Power: CyberPower CPS-1220RMS
Interconnects: Emotiva USS [4], XLR [6], X RCA [4], MUSB [1], X IEC [4] -
I'll try turning down the other speakers and see. In general its just quiet, I hope the amp isn't going out. I just bought the sub two months ago.
If you just bought it two months ago, you my be able to refund/exchange it? It sounds like it is hooked up correctly, maybe check your settings on your reciever, otherwise I would research a possible return.HT Rig
Blu-Ray- 80 GB PS3
Last night I tweaked the settings on the LFE and subwoofer. Still no noticeable bass, there is some bass coming out when I have my ear to it. Maybe its the lfe cord, I'm going to try the parallel wiring to see if that might change things.
I ran the auto setup on my yamaha receiver, for the first time I finally heard the subwoofer. The setup had the crossover at 60 all the speakers on large. Also, I have the dolby dynamic range off. I can actually hear the sub now.:)
I had a similar experience with my Onkyo receiver. The sub was dead quiet. Came to find out the level for the LFE output was almost at minimum due to the auto eq.Brian Knauss
ex-Electrical Engineer for Polk
