Need Help with Choosing Front Speakers for 5.1 HT System
pakuhn
pakuhn Posts: 2
edited November 2008 in Speakers
Hi, I just recently purchased my first home theatre receiver (Harman Kardon AVR 354) and would like to get some opinions on which front speakers to get which would best match the rest of my planned system. I plan to purchase the two front speakers and the center channel first off and then gradually purchase the rest of the speakers within the next several months. I have decided on the CSi A4 for the center channel and am in-between on a set of RTi A5s or Monitor 70s for the front speakers. As far as the rest of the speakers I plan on adding to finish off the setup later are a set of FXi A4s for the surrounds and a DSW Pro 600 for the subwoofer. So which would be the best match for the proposed system?
Post edited by pakuhn on
  • apphd
    apphd Posts: 1,514
    Welcome to CP. I think you would be better off and happier in the long run with the RTi's. But that's just my thoughts.
    Nice receiver BTW.
  • Motzart
    Motzart Posts: 1,075
    I second that on the RTi's.
    The RTi series speakers were nice....love mine!
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • Upstatemax
    Upstatemax Posts: 2,737
    I am very happy with my Monitor 70's... I could not see or hear any difference that made the Rti A5's worth the extra money.
  • McLoki
    McLoki Posts: 5,231
    If you are already set on getting the RTiA4 for a center channel, I would certainly get the front speakers that match it. (the RTiA5 if that is the model you are interested in)
  • McLoki
    McLoki Posts: 5,231
    Ohhh - did not notice the H/K purchase. That should blend very well with the RTiA line....
  • Chitown_Badger
    Chitown_Badger Posts: 66
    I hope this isn't hijacking, but I had a similar question that I wanted to run by everyone...perhaps the answer will further inform the original poster.
    I've got a system consisting of RTi10s and FXi3s, and need to upgrade my center channel. Ideally I would pick up a CSi5/A6, but my current space simply won't allow it (the depth is an issue). I will upgrade in a year or two to the A6, but need something until then. I've currently got a CSR, and that seems to me to be lacking.
    The question is, would I notice a significant difference if I went with a CSi3/A4 over the CSR? The specs seem very similar, but the price makes me think there has to be some performance difference.
    And second question, would it be a bad idea to mix lines for the center channel so I could get the dual 6.5" drivers in a center? I would entertain getting either a CS20 or CS2.
    I'm no audiophile, but if the negatives of mixing lines would outweigh the benefits of having the more full midrange, I'll just go with the A4. Any thoughts would be welcome!
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
    AVR: Pioneer VSX-1018AH
  • Chitown_Badger
    Kex wrote: »
    I find that Polk centers seem to blend very well accross different model lines, but I still prefer to match exactly if I can, so in your case, I would be trying to find a CSi5 (which will probably also be too big for now, in your case).
    Regarding the CSR, the CSi3 or A4 might make a significant difference. Although I currently use a CS400 to match my RT55, I have also found the CS300 and CS245i to be great performers in the same setup. If I had to use either of those because of space concerns, instead of the big CS400, I would still be very pleased indeed. In your case though, the RTi10 are a really big speaker, so even a CSi3 or A4 might not be enough to satisfy you. There's probably only one way to find out if it's worth it, for a temporary solution, until you get the CSi A6.
    Thanks for the reply. You're the second one to tell me it's probably best not to mix lines...so I think I'll have to suffer through a year or two with "just" the RTi10s and a CSi3 :cool:
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
  • pakuhn
    pakuhn Posts: 2
    thanks too everyone that replied... I can't wait to hear how this thing will sound when it's complete. Just one more question.... Would you go with the RTi10s if they were $60 more than the RTi A5s? From what I understand they are pretty similar to the RTi A7's.
  • Chitown_Badger
    pakuhn wrote: »
    The RTi A5's are a nice speaker and I was planning on getting the refurbs off the polk direct store. But I came across a great deal on a pair of new 10s that I couldn't pass up ($400 for the pair total). I've got them hooked up to a HK AVR 147 that only pushed 40 WPC, and they sound great. I'm going to be upgrading the AVR soon, and am excited to hear how they sound with adequate juice. They are more speaker no doubt, but the other knock on them is that you ideally need the CSi5/A6 to fill in a small mid-range deficiency (though you gain the low end definition). You'd be happy with either, you'll just need to put more cash into the sub if you go with the A5s.
    (and yes, the RTi10s are the older model of the A7..cabinet design is different and size is slightly different).
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
  • Chitown_Badger
    Kex wrote: »
    It's not the subject of the thread, but even if I don't use it any more, my h/k 147 really surprised me with its outstanding performance. A great entry level receiver for anyone starting into HT that does not need external amplifier pre-outs or audio via HDMI (video HDMI only).
    Agreed. I like it, but I would like my next receiver to have pre-outs and push more wattage. But I heard, and now agree, that HK receivers easily push as much, if not more, than their quote levels. Which is in direct contrast to most other receivers.
    (the no audio over HDMI thing was only a minor issue when setting up for me...so no biggie there).
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
  • Kchill
    Kchill Posts: 262
    If you could swing it get the csi3 or a4...big difference from that csr...boy that csr was pretty bad when I tried it out...but my csi3 is fan-freakin-tastic!
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • Chitown_Badger
    Kchill wrote: »
    That's the kind of feedback I was looking for :D Done deal. I guess I just wasn't sure that the A4 would differentiate itself...but I'll take your word for it (and will soon find out on my own).
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
