ticking noise
kupaa
kupaa Posts: 5
Hi,I have the rmds1 unit and the sound compleatly went out and now there is a loud ticking noise comming from the unit and when i try to turn it on it shows a error no.3 on it.Any idea...
Post edited by kupaa on
    F1nut Posts: 51,901
    edited November 2008
    Call the bomb squad.
  • Audio NUT
    Audio NUT Posts: 63
    look in the book or call the maker and ask what error 3 is for, there is usually a description of error numbers
  • NotaSuv
    NotaSuv Posts: 3,871
    In the back of the manual that came with the system there are phone numbers to call in case of problems with the unit.......this would be a great place to start..there is also a small trouble shooting guide in the back of the same manual
  • hostchecker
    hostchecker Posts: 8
    damn he was first onthe bomb thing
  • concealer404
    concealer404 Posts: 7,440
    Have you had a valve adjustment in the last couple years?
  • kupaa
    kupaa Posts: 5
    thats funny because that what it sounded like and it got faster and faster each second until i pulled the plug or should i say cut the red wire.
  • Lowell_M
    Lowell_M Posts: 1,660
    doh! your only hope is to bridge a double mint wrapper across the black and red wires and cut the white wire!! (everybody knows that)
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
