Subwoofer to TV line output?
djseafood
djseafood Posts: 73
This is for TESTING purposes only. I received a nice new PSW505 and then promptly dropped it while taking it out of the box (put this down as things you shouldn't do after 30 hours of travel and a trans-Atlantic flight) Anyway, looks like I just smashed the corner of the MDF and *hopefully* everything else is fine. I still have a week until my new receiver shows up and I want to test out my sub to make sure I have totally F'd it up.
So, for this purpose only, can I use the L/R RCA output from my TV and run them to the line level L/R input of the PSW505 using its internal crossover? Is this safe? Again, I just want to make sure the sub is functioning properly and that I haven't damaged anything internally. I'm hoping to hear nice smooth bass with no wizzing or vibration issues caused by the drop.
Thanks in advance for any help! (BTW, I've seen people abbreviate that "Thanks in advance" as "TIA" which makes me laugh because I've just spent 35 days in Tunisia where that stands for "This is Africa") :)
HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
Post edited by djseafood on
  • ShinAce
    ShinAce Posts: 1,194
    edited November 2008
    Perfectly safe, but start with the sub volume at minimum and work your way up once everything is plugged in and turned on.
    edit: I'm too slow.
  • djseafood
    djseafood Posts: 73
    Thanks for your help! And the welcome to CP :)
    Yes, starting with the volume at zero and working up is a very good idea! I'll let you know how it turns out.
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
  • djseafood
    djseafood Posts: 73
    Well, it worked! Sounds pretty good too :) Kinda weird with only the TV speakers supporting it, but I was able to test it out and it sounds as it should . . . at least I think it does with my limited experience :D
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
