Snipped my polyswitches
nadams
Decided last night to open up my SDA 2's. I hadn't really given the crossovers a good lookover since I purchased them, and the previous owner had rebuilt them. A separate thread will be started soon about the quality of the rebuild.
Anyway, while I was poking around, my eye caught those darn polyswitches. Having just recently read so much about the improvement in sound by eliminating them, I decided to go ahead with it. Rather than removing the crossover from the cabinet, I decided to do everything in-place. It was a little crowded, but the 12" passive radiator hole gives more than enough room to get my arms in there.
Snip, solder, screw it back together.
Sound difference? You bet. I have yet to determine whether it is better or not. Keep in mind, I've got 4 sl2000 tweeters squawking in my face, completely unrestrained now. There definately is more detail, but on the sl2000's, it could be just a bit to much. I didn't get a chance to listen to much music, as it was about midnight 'til I finished the modification, and I had work in the morning and all. But I was up 'til around 1 listening to different passages that I'm familiar with. I was picking up detail I hadn't heard before, even in familiar songs.
Next thing I'm going to try, maybe tonight, is to disconnect the dimensional tweeter in each speaker to try to tone the highs down a little. I've been told that this model actually sounds better with only one tweeter running per cab.
Ludicrous gibs!
Post edited by nadams on
Don't forget to let the jumper burn in.
JK
Ben -
I think they're pretty well burnt in already
. I was able to use the snipped poly leads on 3 of the 4. The 4th, I had to use a short piece of wire.
Let's just hope I don't "burn in" my sl2000's now. They're not known for their reliability to begin with. Granted I've never tripped the polys before, even when I was driving them with a receiver. That's why I felt comfortable eliminating them.
Plus, come thursday, I'll be going from a gfa-535 to a 545, which'll get a little more power to them.Ludicrous gibs! -
I think you will really enjoy the 545. Its a great amp, and if you disconnect them dim tweeter I think you will be pleasantly surprised. You may have to replace one of the resistors one the stereo tweeter to bring it back up. I did.
Ben -
Could I just disconnect the dim tweeter and add the resistor between those leads? Would save me having to solder on the board, not that it's a huge deal.Ludicrous gibs!
You have to lower the resistance before the actual XO.
Edit: There is a 3.5r in parallel with a .5uf, and 750pf caps. Snip out both caps, and replace the 3.5r with a 2.7r to 2.5r. This will even thing out;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
