Do Scratches On Equiptment Bother You?
jerrymb
jerrymb Posts: 278
edited January 2010 in Electronics
The dust cover on my turntable is scratched even though I never ever put anything on it. The top of my cd changer has several scratches on it and I have never placed anything on it. Same with my speakers. It just bugs the crap out of me.
Jerry
Post edited by jerrymb on
  • pearsall001
    pearsall001 Posts: 5,249
    edited November 2008
    jerrymb wrote: »
    Kill the friggin cat!! :D
  • BIZILL
    BIZILL Posts: 5,432
    that's why i use microfiber towels to clean.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • jerrymb
    jerrymb Posts: 278
    That's when the scratches started. When I started using expensive micro fiber cloths!
    Jerry
  • shack
    shack Posts: 11,154
    99.9% of the time scratches on the exterior finish of gear have no effect on the sound or video quality of the music and/or movies. The other .1% of the time it's all in your head.
  • BIZILL
    BIZILL Posts: 5,432
    jerrymb wrote: »
    then you somehow picked up larger than the norm debris. a damp microfiber gently run across the equipment should not scratch the finish. this is true of both my auto paint as well as my piano gloss black ps3 which is prone to scratching.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • Mike Kozak
    Mike Kozak Posts: 931
    shack wrote: »
    Oh, no, there is nothing in my head!!!!
  • hearingimpared
    hearingimpared Posts: 21,136
    Scratches drive me nuts only because they will affect the resale value of the unit.
  • McLoki
    McLoki Posts: 5,231
    Thats why I usually purchase my equipment pre-scratched. I get it at a rock bottom price and don't have to stress over the first scratch....
  • dorokusai
    dorokusai Posts: 25,576
    Yes.
  • doug lang
    doug lang Posts: 261
    Bought an outlaw pro and the owner said mint condition. Well there was fresh paint all over it to cover the scratches. And a bad match of paint i might say. That went back in a flash. You spend a lot of money and i can't understand the condition of some audio equip. I think of the resale value and of course showing off my system.
    Oppo bdp 93 Blue Ray
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Polk LSiFXs (surrounds)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • Sherardp
    Sherardp Posts: 8,038
    BIZILL wrote: »
    Same here, also use the ones that are supersoft for camera lens, etc. Hate scrathes and fingerprints too.
  • okiepolkie
    okiepolkie Posts: 2,258
    dorokusai wrote: »
    Yes.
    Mark, are you saying you are ANAL retentive? I would have never figured that out about you :D
    Zach
    Tschüss
    Zach
  • cfrizz
    cfrizz Posts: 13,415
    If the scratches aren't visible (in the front) I don't care. Now seeing fingerprints on the front of my gear drives me nuts!
    VR3 Posts: 29,402
    Scratches can almost make me want to replace a piece of gear - depending on what it is and the ding...
    My Candela has a 1/8" mark on it on the front - dont know how it happened - but I will forever hate being up close to my Candela... :p
  • RuSsMaN
    RuSsMaN Posts: 17,986
    jerrymb wrote: »
    A mark here and there, no. A big 'Rokken with Dokken' sticker on the top/side/facia - yeah.
    Cheers,
    Russ
  • okiepolkie
    For me, I don't have a preference overall. I usually don't keep a piece longer than a 6 months before I switch out to the latest and greatest, so if something does get scratched, it isn't around long enough to bother me.
    Tschüss
    Zach
  • dorokusai
    okiepolkie wrote: »
    Zach
    Absolutely :D
  • janmike
    janmike Posts: 6,146
    ... up the wall.
    Michael ;)
    NORTH of 60°
  • Ricardo
    Ricardo Posts: 10,636
    It does not bother me in electronics, unless it's in the front and very visible. In speakers, scratches bother me even if they are in the back :confused:
    SOPA
  • ben62670
    ben62670 Posts: 15,969
    Sherardp wrote: »
    Finger prints can get you in a lot of trouble depending on where you leave them. Like Doro's equipment:)
    Ben
  • joeparaski
    joeparaski Posts: 1,865
    Wow you guys sure are picky. But...since I have mostly older vintage pieces, I'm quite used to scratches here and there. And since it's almost all rack mounted, I don't see the scratches anyway. Overall, the faces are in pretty good shape.
    So no, the scratches don't bother me.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    BIZILL wrote: »
    I agree with that 100%
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • mmadden28
    mmadden28 Posts: 4,283
    Scratches are inevitable. I hate them, but it really depends on what equipment and where and the circumstance on how they got there.
    IF I paid for a used peice of equipment or furniture and I know it ahead of time-I'm OK with it. If its represented as better than actual or perfect-it irks me.
    If I buy something new-I expect it to be perfect. If I scratch it, that sucks but at least I know I did it. I don't take may car to an automatic car wash (scratch box). If I do its only the water jets only to get the major dirt off-I refuse the towel drying (yeah its amazing how little the water jets do when its not towel dryed). I then hand wash it myself at home.
    On the other hand, I personally prefer equipment or devices that are not prone to fingerprints or spider scratches-can't stand having to baby some things like my 5th Gen iPod or my SB Duet controller. I prefer a flat or satin finish that won't show scratches or prints.
    If the scratches are on a piece of gear in a rack, as long as the marks aren't on the front face-I don't mind so much, even if more than minor. But I don't like a fingerprint marred anything.
    If the equipment is meant to be displayed, even if miirroed, etc-I like it near perfect for display.
    Of course I have two boys (5 and 3), aka maniacs that absolutely love to torment me and put thier butter noodle/melted chocolate no fork using hands all over everything they can possibly get thier hands on, especially the all glass doors that are plentiful about the house. So I'm a bit numb/desensitized right now to most prints but they still irk me. :eek: All the chips and dings in my nice wood tables and entertainment center are not making me very happy either. :mad:
    Oh the LSi-9's yeah I'm almost afraid to touch them-the dust will keep those dust magnets safe with a layer of protection ;):D
    I'm amazed however at these heavily laquered tables at the food court in the mall. They look super smooth and scratchless. With such abuse and high traffic I am simply amazed. Now that would be a cool coating for equipment. Dip the cases in lacquer, then somehow adjust the finish to avoid fingerprints. :D
    ____________________
    Pool: Atrium 60's/45's
  • Willow
    Willow Posts: 11,226
    Sharpie !, they bother me but I touch up with a sharpie
  • mantis
    mantis Posts: 17,327
    I used to be super anal about my gear. I still am to a point but I don't stress over if anything happens anymore. Life is to short to worry about the little things.
    Scratches on top of gear you can't see when Installed mean nothing to me. Bottoms and back of speakers who cares as long as they perform exactly the way they are suppose to I'm cool.
    Going further wire and cables appearance don't tickle me anymore. I'd rather have all black wires with no design at all . I used to love braided wires and cool looking connectors. They just have to perform there job correctly and I'm cool.
    I used to be into changin it up, going silver and all that, now I prefer just plain black gear with maybe cool blue lights. The blue lights still get me a little.
    A good looking pair of speakers still tickle me. It's hard not to get all into a killer looking pair of speakers. I like them more then a cool amp or pre.
    Scratches suck but don't stop the gear from doing there job.
    Dan
  • Ron-P
    Ron-P Posts: 8,520
    Do Scratches On Equipment Bother You?
    Nope, most of my gear came pre-scratched as I buy most everything used.
    If...
    Ron loves a film = don't even rent.
  • TNRabbit
    TNRabbit Posts: 2,168
    shack wrote: »
    McLoki wrote: »
    Willow wrote: »
    Ron-P wrote: »
    x4....
    that said, GETTING the scratches on your "equipment" is usually more fun than the aftermath....if ya know what I mean.....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Fongolio
    Fongolio Posts: 3,516
    A scratch on the equipment doesn't bother me. A scratch on my vinyl can make me need therapy.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • TNRabbit
    Fongolio wrote: »
    Especially when it a DEEP one; it's like a grenade going off!
    TNRabbit
    Sunfire TG-IV
  • hector_c
    hector_c Posts: 11
    no, i'm not bothered by it.
