Denon avr-1400
Codey
I recently got an avr-1400 , but it didn't come with a remote or a manual . Does anybody know which remotes I can use with it or where I can find a manual ?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
Any universal that will control Denon receivers should work...
Check the Denon website for a manual, they have manuals for their discontinued products out there...
By the way, I'm not aware of an AVR 1400 by Denon... -
I've already checked their website and couldn't find anything.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
I did a bunch of research myself before I bought mine, and I don't remember a AVR-1400 either. They did make an AVR-1403, could that be it? Here's a link to where the manual is located.
http://www.usa.denon.com/catalog/products.asp?l=1&c=57Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
If you know the remote's model number, u can try searching for it on ebay. Just needs a bit of patience but you should prolly get one for around 20 bucks or less. Kris
Thanks for your help guys. There really is an avr-1400 though it's tough to find much on them...http://www.wle-shop.co.uk/browser/data/Denon/PDFs/avr1400.pdf
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Yup, that looks like a 1400. It looks like an older version of the 1403 (about the same specs, just looks like new formats came out since then). You can try freemanuals.com (but they really don't have much), or try sending an e-mail to Denon. They should have one somewhere they can get you.
Good luck.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
Hello,
I just joined this group a few minutes ago.
I recently purchased a used avr-1400 and yes - they do exist.
The remote that you need is a DENON RC-832 (See attachment.)
I found a place that sells manuals and I purchased a user's manual and a service manual for the unit.
I'd probably be willing to share them for a financial consieration - they cost me $25USD.
This is the link for the site.
http://www.user-manuals.com/login.php?osCsid=5a78f349abc551d768a7d6947cd2cb3dW.B. Carss
wbcarss@rogers.com
