Recommendation for a subwoofer
Chameleon2
Recently purchased: fronts RTiA1's; surround FXiA4's and have ordered a CSiA4 center speaker.
My current receiver is a Denon AVR1500 (70 watts w/Dolby Surround Sound only).
Will upgrade to something along the lines of an Onkyo 606 (or equivalent; open to recommendations here as well) at some point.
My room is 24ft x12ft with a 9ft ceiling. TV located along one of the 12ft walls.
Seating area is right in the middle, 12ft from the TV, front and rear speakers.
Club Polk experts, what are your subwoofer recommendation(s) for my setup?
thanks
thanks
Post edited by Chameleon2 on
whats your budget?
Don't know exactly what you are looking for as far as power/sound, but I have a PSW125 and I am very pleased with it. It puts out plenty of punch, and sounds great at all levels. I paid around $300 with a 10 year warranty on it at Circuit City, but it was last years model so I got a pretty good discount on it. Like Leroy said, depends on your budget. As for an Onkyo receiver suggestion, I just upgraded to the TX-SR806 and couldn't be happier, it is an amazing reciever for the price (I paid about $750 with 5 year warranty)HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
How do you have the PSW125 oriented?
Is it facing your seating area - does it matter? -
I have it to the left of my front channel (left one) facing my couch about 10 feet away, turned about halfway up. Don't know if this is "correct" but it seems just fine to me.HT Rig
Blu-Ray- 80 GB PS3
Careful, the Onkyo 606 does not have pre-outs, so you will not be able to add amps in the future.
I, like many, will recommend SVS for a sub. Great products and a great company.
http://www.svsound.com/
Good luck putting your system together!bms
Family Room:
Onkyo TX-RZ920
Outlaw 2200 monoblock amps x 3
Sony UBP-X700
Sony A80J 77” OLED
Polk LSiM 705’s
Polk LSiM 706
Polk LSiM 703’s
Polk RTi4's
Dual SVS PB13-Ultra’s
PC13-Ultra
Bonus Room:
Onkyo TX-SR806
PS3
Panasonic TC-P42G10
Polk RTi10's
Polk CSi5
Polk R50's
SVS PB10-ISD
For sale:
Onkyo TX-SR603X -
I have the Polk PSW111 and it pounds, I promise. It's only an 8", but with 300 watts near a corner, it hits hard and has a great frequency spread. Bought for $299 at Best Buy.USMC
POW/MIA
Always remembered...never forgotten
My HT
46" Samsung 1080P LCD LN46A530
Pioneer VSX-1015TXK
PS3
Polk TSi400 towers
Polk CS10 center
Polk PSW111 sub
Polk OWM3 surrounds
Monoprice HDX-401E 4X1 HDMI switcher
Monoprice HDMI 1.3a CL2 Rated cables
MX-850 - For sale!!!!
MRF-250 - For sale!!!!
Harmony 880
Sexy Wife with a lot of WAF -
I have dual Mirage Omni S8s and a Klipsch RW-10d that i swap between.
I would heartily recommend either of these on a budget, otherwise, SVS.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
thanks for the replies....
I just checked the Mirage and Klipsch subs; look great, but I need subwoofers with speaker level input and outputs (should have mentioned this earlier) with my older Denon. These two subs only have inputs (according to the info provided at Crutchfield).
Polk's PSW line all have speaker level inputs & outputs.
Has anyone had a downward and forward firing subs?
What is the difference in effect/sound/etc between the two types? -
Anyone with experience with the Velodyne DLS-3750R?
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=12300&i=2323750RB&tp=187&tab=features_and_specs -
Be sure to check out the Polk DSW lineup.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Go DSW or go home. Simply incredible subwoofers that would be great in your system.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Chameleon2 wrote: »Recently purchased: fronts RTiA1's; surround FXiA4's and have ordered a CSiA4 center speaker.
thanks
Epik subs -- extreme power, very musical, very low priced.
Just received a Valor ($549 - 350W, 15" driver). Sounds really good with my Polk Monitor 70s. I moved the old Velodyne VRP1200 ($250 - 130W, 12" driver) to the bedroom and that sounds ok with Polk Monitor 60s in a smaller room. But go for the Valor for a large room, it is fantastic and since it's sealed it is VERY musical.Living Room system: 52"HDTV, 4 Mon.70s, Epik Valor, Outlaw RR2150
Bedroom System: 2 Mon.60s,Velo VRP1200, HK3490 -
Chameleon2 wrote: »Anyone with experience with the Velodyne DLS-3750R?
I'm not familiar with that particular model. But I can comment with 1st hand knowledge of the SPL-1200R. My room is pretty much like yours (13x32x7) & the SPL's performance is down right awesome for both 2 channel & HT. It does such a fantastic job that I just had to get another one to run stereo subs. It replaced an SVS cylinder sub & boy am glad I did it. -
Did the DSW Pro series replace the PSW303/404/505 series?
Amazon has a PSW505, new, for $280.
Thanks again for all the info.
