Recommendation for a subwoofer
Chameleon2
Chameleon2 Posts: 112
Recently purchased: fronts RTiA1's; surround FXiA4's and have ordered a CSiA4 center speaker.
My current receiver is a Denon AVR1500 (70 watts w/Dolby Surround Sound only).
Will upgrade to something along the lines of an Onkyo 606 (or equivalent; open to recommendations here as well) at some point.
My room is 24ft x12ft with a 9ft ceiling. TV located along one of the 12ft walls.
Seating area is right in the middle, 12ft from the TV, front and rear speakers.
Club Polk experts, what are your subwoofer recommendation(s) for my setup?
thanks
Post edited by Chameleon2 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited November 2008
    whats your budget?
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Don't know exactly what you are looking for as far as power/sound, but I have a PSW125 and I am very pleased with it. It puts out plenty of punch, and sounds great at all levels. I paid around $300 with a 10 year warranty on it at Circuit City, but it was last years model so I got a pretty good discount on it. Like Leroy said, depends on your budget. As for an Onkyo receiver suggestion, I just upgraded to the TX-SR806 and couldn't be happier, it is an amazing reciever for the price (I paid about $750 with 5 year warranty)
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Chameleon2
    How do you have the PSW125 oriented?
    Is it facing your seating area - does it matter?
  • wutadumsn23
    I have it to the left of my front channel (left one) facing my couch about 10 feet away, turned about halfway up. Don't know if this is "correct" but it seems just fine to me.
    HT Rig
    Blu-Ray- 80 GB PS3
  • bms
    bms Posts: 182
    Careful, the Onkyo 606 does not have pre-outs, so you will not be able to add amps in the future.
    I, like many, will recommend SVS for a sub. Great products and a great company.
    http://www.svsound.com/
    Good luck putting your system together!
    bms
    Family Room:
    Onkyo TX-RZ920
    Outlaw 2200 monoblock amps x 3
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    Dual SVS PB13-Ultra’s
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
  • A/VUSMCSSGT
    A/VUSMCSSGT Posts: 15
    I have the Polk PSW111 and it pounds, I promise. It's only an 8", but with 300 watts near a corner, it hits hard and has a great frequency spread. Bought for $299 at Best Buy.
    USMC
    POW/MIA
    Always remembered...never forgotten
    My HT
    46" Samsung 1080P LCD LN46A530
    Pioneer VSX-1015TXK
    PS3
    Polk TSi400 towers
    Polk CS10 center
    Polk PSW111 sub
    Polk OWM3 surrounds
    Monoprice HDX-401E 4X1 HDMI switcher
    Monoprice HDMI 1.3a CL2 Rated cables
    MX-850 - For sale!!!!
    MRF-250 - For sale!!!!
    Harmony 880
    Sexy Wife with a lot of WAF
  • concealer404
    concealer404 Posts: 7,440
    I have dual Mirage Omni S8s and a Klipsch RW-10d that i swap between.
    I would heartily recommend either of these on a budget, otherwise, SVS.
  • Chameleon2
    thanks for the replies....
    I just checked the Mirage and Klipsch subs; look great, but I need subwoofers with speaker level input and outputs (should have mentioned this earlier) with my older Denon. These two subs only have inputs (according to the info provided at Crutchfield).
    Polk's PSW line all have speaker level inputs & outputs.
    Has anyone had a downward and forward firing subs?
    What is the difference in effect/sound/etc between the two types?
    treitz3 Posts: 20,207
    Be sure to check out the Polk DSW lineup.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    treitz3 wrote: »
    Go DSW or go home. Simply incredible subwoofers that would be great in your system.
  • rru2s
    rru2s Posts: 90
    Chameleon2 wrote: »
    thanks
    Epik subs -- extreme power, very musical, very low priced.
    Just received a Valor ($549 - 350W, 15" driver). Sounds really good with my Polk Monitor 70s. I moved the old Velodyne VRP1200 ($250 - 130W, 12" driver) to the bedroom and that sounds ok with Polk Monitor 60s in a smaller room. But go for the Valor for a large room, it is fantastic and since it's sealed it is VERY musical.
    Living Room system: 52"HDTV, 4 Mon.70s, Epik Valor, Outlaw RR2150
    Bedroom System: 2 Mon.60s,Velo VRP1200, HK3490
  • pearsall001
    pearsall001 Posts: 5,360
    Chameleon2 wrote: »
    I'm not familiar with that particular model. But I can comment with 1st hand knowledge of the SPL-1200R. My room is pretty much like yours (13x32x7) & the SPL's performance is down right awesome for both 2 channel & HT. It does such a fantastic job that I just had to get another one to run stereo subs. It replaced an SVS cylinder sub & boy am glad I did it.
  • Chameleon2
    RuSsMaN wrote: »
    Did the DSW Pro series replace the PSW303/404/505 series?
    Amazon has a PSW505, new, for $280.
    Thanks again for all the info.
