High/Low power amplifier or receiver
muncybob
muncybob Posts: 3,267
edited November 2008 in Electronics
I see many references to low and high power amps....just what criteria determines if an amp is high power...or low for that matter?:confused:
Yep, my name really is Bob.
Post edited by muncybob on
  • Early B.
    Early B. Posts: 7,900
    Like everything else in audio, it's purely subjective...
    "God grooves with tubes."
  • jon s
    jon s Posts: 905
    my guess is that anything under a 100wpc is low powered... but amp ratings can be very misleading. Most of the companies now rate their equipment with two channels being driven when tested. For example, Sony nominally rates their receivers 100-120wpc with two channels driven. When driving all seven channels, they drop to about 30-45 watss which is a big 6dB loss in volume.
    Conversely, Onkyo rates their top tier receivers at ~120-140wpc with two channels driven. Reviews shows that the receivers can still deliver a considerable 100-120wpc when all channels are driven.
    The difference here is that the Sony does not have a power supply big enough to supply the current required to maintain the power output. The Onkyo OTOH has a large power supply which is quite powerful. It shows up in the weight of the receiver, Sonys weigh in at about 30-40lbs, and the Onkyo weighs about 45-55 lbs. Opening them up reveals the Onkyo has huge power transformers compared to the Sonys.
    So if you are looking for a powerful receiver, do your research and see how the units are reviewed at A/V sites.
  • curved
    curved Posts: 664
    Kex wrote: »
    Do you mean "high power" or "high current"?
    I'm sure that's what he meant to say.....
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
    mhardy6647 Posts: 35,230
    The Pioneer SX-34/SX-34B(aka Allied 333 and Knight 333) 6BM8 push-pull stereo receiver (at about 8 watts continuous per channel) would qualify as low-powered. Not a bad little receiver, though, attractive and relatively inexpensive on the used market.
    The Sansui 221 solid state stereo receiver was also 8 wpc:
    on the other hand...
    A Pioneer SX-1980 solid state receiver would qualify as high-powered at 270 watts continuous per channel into 8 ohms).
    The winner of the 1970s (i.e., FTC-power-spec-era) power wars, though, was the Technics SA-1000 at 330 continuous watts per channel into 8 ohms.
    In between there was ahem the Marantz 2600 at 300 watts per...
    That's pretty much the gamut :-)
  • muncybob
    High current is what I meant...sorry!
    Those oldies brought back some memories!
  • apphd
    apphd Posts: 1,514
    mhardy,
    Boy that did bring back some memories.:p I had a Technics SA1010 (early 80's) only 120wpc but it did sound nice and could run MM and MC cartridges on a switchable phono input. Overall build quality wasn't all that great but it was my first real "high end" receiver. That's gone but I still have the speakers I bought to go with it. Genesis Physics 320's they're sitting in a spare room with replacement surrounds waiting for me to get time to replace them.
    muncybob wrote: »
    oh. nevermind. :-)
  • John30_30
    John30_30 Posts: 1,024
    Dear God, that Marantz wrapped with padauk is schweet. Doesn't even look like they oiled it or anything.
    It's a monstrosity. They're known to have somewhat undersized power transformers, unfortunately.
