1.2TL's?
dr.evil
I picked up these speakers about a year ago, and just figured they were the 1.2TL's. However the other day when I was was playing with them, I noticed the 1.2TL model is no where to be found on them. Did polk make any speakers that were identical in looks to the 1.2's and are actually something else? Or are they just not marked 1.2TL? Here is a picture of the back of one of them, hopefully someone can recognize them! Oh and I am still in need of an interconnect cable, so if anyone has one, please let me know!!
Thanks in advance
Thanks in advance
Main System / Phase Linear 400 Amp, 4000 Pre, 5300 Tuner / Pioneer P-D70 CDP CT-F9191 Tape H-R9000 8-Track / Kenwood KD-750 TT / Polk SDA SRS 1.2TL Loudspeakers / Conion C-100F Gehttoblaster / Omnibot 2000 Robot that plays tapes
Post edited by dr.evil on
pic ain't showin' up. polk made three models of the 'big ones'. the original sda-srs. then the sda-srs 1.2 and then finally the sda-srs 1.2TL. they will be labeled as such on the back.
further information to be found here ----> www.polksda.com
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Looks like they are the original SDA SRS as they are not marked 1.2 or 1.2TL. I wasn't able to really tell what the differences were from the website, are there any?Main System / Phase Linear 400 Amp, 4000 Pre, 5300 Tuner / Pioneer P-D70 CDP CT-F9191 Tape H-R9000 8-Track / Kenwood KD-750 TT / Polk SDA SRS 1.2TL Loudspeakers / Conion C-100F Gehttoblaster / Omnibot 2000 Robot that plays tapes
Some, for whatever reason, just say 1.2
You can easily tell the SDA SRS from the later 1.2's and 1.2tl's by the front crossover plates bolt pattern. The 1.2's have 8 bolts in a rectangular pattern and 1 in the center.
The color of the tweeters is the giveaway on the difference between the 1.2 and the 1.2tl. The 1.2's have the 2000 tweeter, and they are murky, yellowish.
The l.2tl's have the 3000 tweeter which is silverish/metallic looking.
*PS, a picture of the fronts of the speakers, with the grilles off would make it easier to help identify them.
-Luc -
You can't always rely on the label. My 1.2's are labeled "SDA SRS XXXX" but have the pin/blade interconnect and the SDA drivers are stamped SRS 1.2. I questioned Ken at Polk some time ago about this and this was his response:
"Unfortunately we didn't keep very good records of serial numbers and their corresponding model numbers. In fact, there's none. The only real way would be to simply remove one of the SDA 6.5" drivers from the cabinet and look at the label on the back. If you see MW6511, then it is a "1.2" if it is MW6503 then it is a "standard" SRS. This is one of the outside SDA drivers."Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
Unfortunately, when it comes to SDA's, the only way to be sure of what you have is if you fall into one of these categories:
1. You purchased the speakers new from a dealer and you received a receipt verifying the model number.
2. You purchased the speakers from the original owner who has a receipt verifying the model number.
If you do not fall into either of the two categories above, you must do some research. Positive identification is complicated by the following:
1. Polk would use up parts from previous production runs on new models. This is why some SDA 1.2TL's have SDA 1.2 labels. Another example is, as trubluluc said, the 1.2's crossover plate has 8 bolts in a rectangular pattern and 1 in the center. The original SDA SRS's crossover plate has 8 bolts in a rectangular pattern and 5 bolts in the center. However, some of the 1.2's made early in its production run used leftover crossover plates from the SRS.
2. Some owners would install the wrong drivers and tweeters if a repair was required or in a misguided attempt to "upgrade" their speakers.
The schematics for all three versions (SRS, SRS 1.2, and SRS 1.2TL), as well as a chart listing the driver and tweeter differences between the various models is given in this thread.
The original SDA SRS had end caps made of laminated strips of solid oak and it used a blade/blade interconnect cable. The SRS 1.2 and SRS 1.2TL had end caps made of oak or walnut veneer over MDF with edge banding and they both used a pin/blade interconnect cable.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I bought my SDA-SRS speakers new in Japan (military) in September 1987. They have traveled with me ever since, through multiple moves in their original boxes. My original midrange drivers are stamped with the date April 1987. I agree with all that DarqueKnight has said except for the the one caveat that the SDA-SRS (besides the solid oak) were also made with solid walnut end caps. This is what appear to be on mine. Can anyone else verify this?
DarqueKnight wrote: »1. You purchased the speakers new from a dealer and you received a receipt verifying the model number.
Doesn't work that way, either. The original owner of my 1.2TLs bought and paid for 1.2s, but was delivered 1.2TLs because they changed over right after he signed the paperwork. Everything, including the speakers, say "1.2" on them and that's what he assumed they were all this time. -
...the SDA-SRS (besides the solid oak) were also made with solid walnut end caps. This is what appear to be on mine.
You are correct:
"SDA SRS and SDA 1-As are available in a beautiful hand-oiled oak or walnut finish." Polk Audio 1985 brochure.
"The top and side panels are wood, in a choice of oak or walnut finish..." Stereo Review, November 1985, page 88.
"Some of the earlier SRS's had oak or walnut end caps made of laminated boards." SDA Compendium 2nd Ed., page 25.John in MA wrote: »Doesn't work that way, either. The original owner of my 1.2TLs bought and paid for 1.2s, but was delivered 1.2TLs because they changed over right after he signed the paperwork. Everything, including the speakers, say "1.2" on them and that's what he assumed they were all this time.
Then it would seem that the only positive identification method for SDA's is to take them apart.:(Proud and loyal citizen of the Digital Domain and Solid State Country! -
That's pretty much what happened with me, also. When I ordered my SRS's in Sept. 1988 at the now defunct Stereo City in Augusta, GA, I was unaware of an upgrade from SRS to SRS 1.2, as all my paperwork said SDA SRS. Apparently Polk was just beginning to ship 1.2's and I got the "latest and greatest" 1.2 version.
I'm starting to get these things fixed up and ready for action, however am in need of the interconnect cable. Its appears I need the pin/blade type, here is a picture:
Click Here
Anyone know where to get an original or aftermarket cable? Tried ebay and all I found was the blade/blade version. I'd like to just purchase one and not go through the trouble of building one.
thanks in advance.Main System / Phase Linear 400 Amp, 4000 Pre, 5300 Tuner / Pioneer P-D70 CDP CT-F9191 Tape H-R9000 8-Track / Kenwood KD-750 TT / Polk SDA SRS 1.2TL Loudspeakers / Conion C-100F Gehttoblaster / Omnibot 2000 Robot that plays tapes
mmm...twin turbo sda's! sorry, just saw your other photobucket pics.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
thanks in advance.
I had to make my own pin-blade cable as I couldn't find an original. However, since I used top parts, I feel mine is superior to stock anyway. :cool: -
Bought my SRS's in 1988 and they were discribed as SRS on all the paperwork. I didn't discover I actually have SRS 1.2's until last year. Mine say SRS, have the 8-bolt/1 bolt XO plate, solid wood incaps, blade-pin connector and 6503/6511 drivers.'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
'86 Polk SDA CRS+
'84 Polk Monitor 10A (Peerless tweeters)
'05 HSU VTF-3 Sub (Original OEM)
'20 HSU VTF-3 Sub (three more, 100% cloned)
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
'88 Adcom GFA-555 (upgraded/restored)
'88 Adcom GFA-555 (a second one upgraded/restored)
'05 Onkyo DV-555 media
'89 Fosgate 360 Digital Space Matrix
'89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
'91 Kenwood Basic M1D Amp
'89 Pioneer Laser Disc media
'89 Sony SuperBeta HiFi media
One PGA2310 based custom built remote volume control
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's
