speakers speakers speakers............so now what??
reeltrouble1
reeltrouble1 Posts: 9,312
edited November 2008 in 2 Channel Audio
As much as I enjoy my Amazings I suppose it was inevitable that the itch for something else would start, so since I now have the BAT VK-120 tube amps in the rig the question becomes what next? I do still have the BAT VK-500 power amp as it did not sell in our FM and I just might keep it although the tube amps have plenty of low end slam and are marvelous in the mid range and top end, still having both gives the option of using this massive powerful sand amp if needed.
Going to be hard for me to go back to a box, not really going for Maggie as I recall they are a bit forward for me, the Woodshed is not that large I use a 12' 6" or so wall with 9 ft of usable space to the corner which means about 6ft usable to keep the speaker off the wall, I thought maybe some Sophia or even Watt Puppy or maybe Quad. Also the Focal Utopia line looks interesting but also looks big, others I have looked at are KEF, Vandersteen and Revel. Just researched not heard them.
As some of you know I like all genre's especially blues, rock, folk, pop, but have my all jazz and classical days as well, so tough to find a speaker to do all of that, the Amazing's come close but shine the most with recordings where the instruments have alot of air around them so hard rock is the most difficult for them to produce. I do have to face the fact that this rig now needs quality recordings of whatever genre or else you are going to hear all the nasties that an engineer can muster on some of these discs.
So I am looking for suggestions, speaker must be good looking with solid build standards, provide bass slam but be smooth and balanced overall, imaging and soundstage, well I like both with a nod toward imaging if I must pick, they need to be around 90 db or better efficient and not need a huge room to shine. I am very biased to floorstanders and do not want to add a sub.
RT1
Post edited by reeltrouble1 on
«13
  • Early B.
    Early B. Posts: 7,900
    Get the Emerald Physics CS-2.
    "God grooves with tubes."
  • dkg999
    dkg999 Posts: 5,647
    Quad's would not be a bad choice, and since you like to change things up every once in a while, it's not like your looking for a speaker to be a life partner. I would take a serious listen to the Maggie 3.6R's before you write them off.
    DKG999
  • TNRabbit
    TNRabbit Posts: 2,168
    I've heard & like the Sunfire CRM-3s. Small footprint (wall mountable, actually), great soundstage, ribbon drivers. A bit pricey, though...and they DO require a sub.
    Are you selling your Plats?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Ricardo
    Ricardo Posts: 10,636
    I would look into Tyler. The Linbrook Signature system is 92 db, and they like tubes; I run mine biamped with a pair of TAD-60's for a while and they shined. They are good with all kinds of music, and can be run with no subs. They also look beautiful.
    They are also front ported which is a plus for small rooms.
    Edit: this is probably the speaker that I miss the most; in my very short list to own again
    SOPA
    VR3 Posts: 29,448
    Ive heard mixed reviews on Tylers new stuff --
    So, if Tyler is a consideration get em now!
    As for Wilson and JM Lab Utopia - you need MASSIVE amounts of room for those speakers...
    The Grande Utopia in my Dad's 35'x25'x12' room are still way to big...
    They sound like crap in there...
    Good luck
  • Face
    Face Posts: 14,340
    I recently heard some of the new KEF's. Since you stated you don't like forward speakers, they may not be for you, but I wouldn't turn down a listen.
  • lakesailor
    lakesailor Posts: 319
    Early B. wrote: »
    I have to admit I keep hearing amazing things about those Emerlad CS-2's. Recently chatted with the owner of a hi-end specialty amp. company and he recently heard a pair and said "you know the moment you listen to them you are listening to something special."
    This from a guy who listen's to his amps on dozens of different hi-end speakers every year and as an amp manufacturer usually careful to not pick a favorite.
  • reeltrouble1
    well, forward is somewhat subjective, I do not like speakers that reduce the depth of the stage by moving certain instruments so much forward you lose what is behind them, this is an area the Amazings excel in as the they are very holographic in the presentation.
    anybody have experience with the JM Labs Profile 928?
    RT1
  • SolidSqual
    SolidSqual Posts: 5,218
    If you don't have a lot of cash to spend and want to achieve high end sound with the low-end more than intact, then you'd be hard pressed to find something better than the CS2s.
  • reeltrouble1
    cash is not the primary issue, sound quality is. So the big Wilson's are out.
    RT1
  • Face
    Face Posts: 14,340
    http://74.59.244.35:9081/gemmeAudio/features/Products.html
    I demoed the Tanto v.2's recently and they were a very sweet sounding speaker, my favorite to date actually.
  • george daniel
    george daniel Posts: 12,096
    Ted,, Out of all the suggestions,I can speak to the Tylers,,they do,in fact sound very good with tubes(driving a pair of 7U's with a 40 watt tubed anthem w/pio caps)I think something in the "linbrook" lineup might be perfect for your room.Yours is a enviable situation;),Good luck,,the hunt should be fun.
    mhardy6647 Posts: 35,060
    Altec A-5 Voice of the Theatre. Not attractive but awfully beguiling.
    That's an A-5X on the bottom left (photo from www.lansingheritage.org )
  • McLoki
    McLoki Posts: 5,231
    The Watt Puppies are the best speakers I have ever heard. I liked them better than the Maxx. (and the sophia)
    I also recently heard the Revel ultima salon 2's and thought they just sucked. Sounded very clean but did not enjoy anything I heard through them.....
    Enjoy your search....
    Michael
  • LuSh
    LuSh Posts: 887
    Hi Reel,
    While speakers and transducers are probably the most subjective component of any audio system I thought it would be fun to throw in some names that I've heard the last couple of years that have really turned my head (and ears). These speakers probably won't be mentioned in this thread but deserve a look.
    Oskar Kithara's
    http://www.uhfmag.com/Issue59/Kithara.html
    A Swiss Full range design. You've stated you might not be comfortable with normal box speakers and these will provide you with an open sound you simply can't get from a normal box speaker. At 94db you should have no problems running with tubes. I heard these speakers for a couple of hours with a Benchmark DAC, Copland Pre and Blue Circle Hybrid amplifier. The sound was very deep and airy. The soundstage was incredibly wide but instruments were still imaged vividly in the front. Musical selections ranged from Diana Krall to Pink Floyd's The Wall and each disc was played with superb realism. Distance from the back wall is required, at least 4 feet.
    Aliante Zeta Ones
    http://www.tnt-audio.com/casse/onezetae.html
    I will be honest. These speakers were part of a system I consider to be the best setup I've ever heard in a personal dwelling and has super seeded most dealers acoustically treated show rooms. This Italian stand mount has no real tricks simply a collection of outstanding parts; Scanspeak Tweeter with SEAS woofer and a fairly efficient cross over. The speakers were fed by an Ayon CD-1 disc player (The best redbook player I have ever heard; and I've heard alot) and a BlueNote Demidoff Signature Integrated that is entirely Class A. This combination produced one of the most extended trebles I've heard without being harsh. I've listened to these speakers in a small room with horrible acoustics and a basement with concrete floors fed through Apple TV. Both setups were impressive. These speakers are incredibly quick, throw up the largest soundstage I've heard from a standmount and dig deep. I don't know what the spec's are on the low frequency's but if somebody told me 39Hz I wouldn't be surprised. These speakers are no longer being produced but offer the best of all worlds. I listened to hours of Electronic, Jazz, Rock, Alternative Rock and nothing made these speakers sound dishonest or bad. Every time I listen to this system I go back home, look at my Dynaudio's and Krell combo, and simply shed a single tear.
    The owner of this system phoned me last week and suggested he's found another gem which trumps that Aliante's:
    BlueNote Ducales
    http://vokuz.com/en/high-end-audio-39/bookshelf-monitor-120/ducale-speaker-monitor-1398.html
    While I have not had a chance to listen (I will next week) I've been informed that these beat the Aliantes in all aspects. I will have to make my own conclusions as we've disagreed in the past.
    Krell Resolution 1 or 2
    http://www.stereophile.com/floorloudspeakers/1104krell/
    Not known for their loudspeakers Krell makes some of the best I've heard. Warm, open and incredibly dynamic. These things love high SPL's and can dig deep yet still sound open and transparent. If I had the space I might own a pair of Resolution 3's. The only down fall would be they require SS power as opposed to tubes but the prices have dropped like a rock and these speakers can be picked up for insane prices as Krell has decided to clear the line. The ring radiator tweeter reminds me alot of the Polk LSi series but everything is kicked up a notch or three. A great all round performer.
    Lastly....
    Reference 3A's Grand Veena's
    http://www.enjoythemusic.com/SuperiorAudio/equipment/0108/grand_veena.htm
    I will be honest. I have no personal experience with these speakers...YET. I can tell you however that an audiophile friend has suggested they are by far the best speakers he's heard at nearly any price. At 90db they might work well with tubes. I've been told it can work with Class A biased SS or tubes. I should be listening to these extensively in the near future, I will post my impressions if you care to read about them.
    Well theres a few suggestions. It might be hard to find dealers for most of these brands but it sounds as if you might tackle this blind to mix it up a little. All the speakers I've mentioned either have or should have reference level sound quality. The Aliantes might have been aided in some very exotic high end up stream components. The Kitharas had my hands twitching, my feet tapping and my mind frantically trying to come up with an excuse as to why I shouldn't completely change my system.
  • janmike
    janmike Posts: 6,146
    Ted, have you tried tubes with any of the Proac line?
    Michael ;)
    NORTH of 60°
  • George Grand
    George Grand Posts: 12,258
    Son, you sell those Amazings, and somewhere down the road, you will rue the day you sold them.
    Grand/Nov08
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Sell the Amazings to me.... I give you visiting rights ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Face
    Face Posts: 14,340
    http://www.sumikoaudio.net/sonus/prod_elipsa.htm
    I plan on getting my ears on these soon.
  • amulford
    amulford Posts: 5,020
    Have you thought any about THIEL Audio? I have an older set of these, haven't listened to the newer stuff, but it's basically the same design premise.
    tonyb Posts: 33,072
    Sp tech timepiece,that waveguard thing sounds interesting and people can't stop going goo-goo over the sound quality.
  • TroyD
    TroyD Posts: 13,124
    Quads, man, Quads.
    That said, I concur with El Roma.....stick the Amazings in the boxes and hang on to them.
    That said, there are some speaks by Sonus Faber I wouldn't mind getting an ear on.
    BDT
  • reeltrouble1
    I am sorry, did I say I was selling the Amazings?????? I still have an image of Dipole Dan standing in the street in front of Al's lamenting the recent sale of his.
    They may still be number one, but hell, its time to hit something else, no rush, and there are some excellent suggestions that I had not considered.
    BDT there are some 989 for sale in Charleston.
    RT1---speakers speakers speakers
  • SolidSqual
    I know a guy selling his LS6s for $3K if you are interested.
  • George Grand
    The little Sonus Fabers with the 6" woofer that my neighbor Dean traded in for MMG's gave me a boner.
  • dkg999
    dkg999 Posts: 5,647
    Face wrote: »
    I've spent some time with the SF Cremona Elipsa's! Absolutely incredible. If I win the lottery or 10 yrs down the road when they are going for cheap on the used market, I will own a pair.
    DKG999
  • reeltrouble1
    Its nearly always better to let Richie Rich take the first hit.
    The little Sonus and the top end Legacy have peaked my interest a bit, along with one Lush suggested, there sure are alot of great speakers to pick from so the chase is half the fun. Those Quad 989 in Charleston are available and the guy wrote me this morning with some pics.
    If I go Sonus big boys I am going Amanti. I retire in 2+ years so they may be my gift to myself, beats the hell out of some knock off watch.
    I think I might move the Amazings into the big room upstairs, put the sand amp back on them and let them really breathe, then put some other speaker in the Shed with the tube gear, although, I did get some major wood last night in the Shed doing it with Ann and Nancy Wilson with the tube gear and their SACD. Damm that Ann has some pipes.
  • shack
    shack Posts: 11,154
    IMO the Thiel CS6 or CS2.4 should be added to the short list to be considered.
  • TroyD
    TroyD Posts: 13,124
    Ted,
    If you can, get an ear on them. In about 6 months, you can hear mine.....I think you will like.
    That said, I've heard the 989's have issues in smaller rooms, in which case the 63's/988's would be up your alley. Either way, worth a listen.
    BDT
  • hearingimpared
    hearingimpared Posts: 21,136
    Ted,
    Jas makes some beautiful sounding floor standing speakers for as low as $5K. You can see the full line here; http://www.questforsound.com/speakers/spkrs_jas.htm. Everytime I go to the store I wish I had the bread to buy the Odins.
    Steve the owner of Quest for Sound will give you a great price. The problem is getting your ears on them in your area.
