Analogmetric 5670 buffer amp
jjaudio
jjaudio Posts: 9
edited November 2008 in DIY, Mods & Tweaks
I bought a 5760/6N3 tube buffer amplifier from AnalogMetric last week. The PCB is in high quality, 2.5mm thickness, double blue layer. Just spent half an hour, all the components were soldered. Components come with good quality. They uses WIMA, Nichicon capacitors and Dale resistors. Once I connect it to the optional toroid transformer (9Vx2 and 15Vx2) and my DAC, CLEAR and WARM tube sound come out without adding any distortions to the original signal. Also I connect this tube buffer amplifier to my headphone and Marant 7C preamp. It is amazingly sound good. It is absolutely the best cost effective way to upgrade my Hi-Fi!!
Post edited by jjaudio on
  • mmadden28
    mmadden28 Posts: 4,283
    Reported.
    ____________________
    Pool: Atrium 60's/45's
