recommendations on equipment and questions
Cthulhu11
Cthulhu11 Posts: 69
Looking for recomendations on equipment this is what ive recently purchased:
DENON AVR-1906 (Reciever)
ADCOM GDA-600 (DA convertor)
ADCOM GFA-555 (Amplifier)
ADC Equalizer with/ RTA
POLK SDA-1C
Ive been told that i might need a preamp instead of using my denon receiver, but ive also been told but splitting up the equipment i run a great chance of noise distortion. Could anyone give me a little more insight?
THX!:)
Post edited by Cthulhu11 on
  • george daniel
    george daniel Posts: 12,096
    edited November 2008
    Cthulhu11 wrote: »
    POLK SDA-1C
    THX!:)
    I'd sell the receiver,and EQ,, buy a tubed pre and you are golden.Just my .02. Have fun,,nice rig that you got started.BTW,, you might want to replace the tweeters with the RDO replacements. :)
  • WilliamM2
    WilliamM2 Posts: 4,808
    That Denon has pre-outs, so it will work with your amp. Get rid of the EQ.
    What source will you be using the DAC with?
  • ajcllc
    ajcllc Posts: 138
    The Denon is a good receiver, but I have to agree with George. Get a tube preamp instead. You can find a good starter tube preamp such as a Dynaco for about $150 to $300 depending upon the condition. If you do go vintage on the preamp, at least have the caps replaced.
  • Cthulhu11
    Cthulhu11 Posts: 69
    I have two options with the DAC, i can use it with a panasonic dvd/cd player, or an adcom GDC-575, what i would really like to use is a CD transport but can't seem to find one that is reasonably priced. I appreciate everyones help!
  • marvda1
    marvda1 Posts: 4,958
    the denon is a good receiver? compared to what? the denon pma 2000 ivr two channel integrated amp destroys all of denon's receivers sound wise.
    Puritan PSM156
  • dudeinaroom
    dudeinaroom Posts: 3,609
    I've got the previous silver faced version of your denon, Dump the Eq, if you have a surround sound setup, theat denon will work fine with that amp( I had one ). If you want to seriously listen to 2 ch meterial loss the E.Q and the receiver, and get a preamp, Can't recomend tube, as the last time I heard any I was about 5( 28 years ago).
    Good luck,
    dude
