Yet another question - Direct TV or Dish Network
hoosier21
Well we are moving this weekend into the new house (new to us). and it has dawned on me I have done nothing about getting a service set up for the TV.
I have had Dircet TV in the past and liked it, but I have not had it for a couple of years and was wondering what is the current leader in the Sat. TV race.
Thanks again for all your suggestions.
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
If you don't mind shelling out a couple bills, Directv does have an exclusive on the NFL Sunday Ticket.
I have had both Dishnetwork and Directv. To be honest, I would have stayed with Dishnetwork except for the fact that I was not authorized to receive locals for my area, and I just got fed up with the static on the shows I loved, like Scrubs and NFC football.
With both I had satellite recorders that changed the way I watched television, with a small tilt towards Directv, since when you fast forwarded through commercials and realized the show was back on and hit play, it would back up a bit so you didn't miss anything by button-push-lag.
Dishnetwork I believe had a slightly better picture on my system (running S-video switching through my receiver), so if you can get your locals, I'd use them. But you're definitely not disadvantaged by using Directv.Denon 1803 Receiver
Denon HDCD CD player and DVD Player
DTV HD Tivo Recorder
AR Pro Series Interconnects
Kimber Kable
48 inch Magnavision HD projection
Polk CS350 center channel
Polk RT10s
Polk RT/fx
AR 12" slot loaded sub
(Mirage Omnisat system almost complete) -
I use Dishnetwork and really like the direction that they are taking with regards to HD programming. WWW.DBSTalk.com has a lot of info about what is going on in the DBS arena. you might want to look at www.dishnetwork.com and find out if your local stations are available, for a lot of people that can be a make or break item.
NFL package is not on my list of wants. I barely watch what is on the networks.
I am looking at 3 TVs, one at least to have the ability to record, and have a digital output, the other two will be standard for the bedrooms.
HD is in my near future, I am lookinig to get a new TV also.
I am outside of Atlanta, both systems offer local channels.Dodd - Battery Preamp
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I have Directv because of the NFL Ticket and NBA. It really doesn't matter. Directv did buy dishnetwork though.....just and F.Y.I.Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Car speakers polkaudio EX 369, DB 650 -
Somebody correct me if I'm wrong, but currently there is no combo recorder that does HDTV, right?Denon 1803 Receiver
Kimber Kable
Polk RT10s
Polk RT/fx
Dishnetwork will be comming out with their model 921 PVR this year.
The only HDTV receiver you can use with dishnetwork is their echostar 6000. That is it..no other options.
With directTV you have the option of several different makes..Samsung, Sony, Panasonic etc. Also directTV has HDnet avalilable. And as stated above the local package may or may not be available with dishnetwork.
FrankZ..polk a dweeb...what the hell is that:Dsuds, suds and more suds! -
Correction, Dish wanted to buy Direct, buy the FCC killed the deal.Political Correctness'.........defined
President of Club Polk -
So which ones can you receive HDTV signals on?
I am using Dish for the purpose of more HD channels available and the price is a bit cheaper. If youre into using the PVR functions Direct has Dish beat because they use the TiVo system which is so user friendly that the most technically challenged will have no problems. Another nice feature about the Dish/TiVo combo is that certain units can be hacked and upgraded with more time. Frank is right on about the new Dish 921 system as it will be able to record SD for 180 hours and HD for 25 Hours w/ firewire and DVI outputs. Its capable of 50 HD channels and will be available by the end of summer."The only way to get rid of a temptation is to yield to it."
Would you have to pay for the upgraded 921?
Being lazy here, I am in Atlanta area, if my local channels offer HD, are the "local channels" on Dish HD?Dodd - Battery Preamp
Philips DSHD800R, Samsung ST-160, Toshiba 3100, Sony HD200 and a few others. Will do some research and add to this list.suds, suds and more suds! -
No, you would have to install an antenna to receive your local OTA DTV channels which the 6000 is capable of.suds, suds and more suds! -
Here is my setup:
Echostar 6000 HDTV receiver
Winegard directional antenna
two Dishnetwork dishes..one for regular programming and one for HDTV
Channel Master signal amp
Channel Master antenna rotor
Using the antenna I receive all the Philadelphis HD channels which are CBS, ABC, WB, UPN, PBS, and sometimes NBC.
Using the dish I receive 1 HD HBO and Showtime channel, HD Discovery channel and HD CBS out of N.Y. which was included with my local package.
Tell ya man there is nothing like true HDTV!! It's the next best thing to 3D. Actually looks like it sometimes.suds, suds and more suds! -
So I take it there are only a few HD channels even on satelite?
madmax you are correct. What I am receiving is all that is available right now from Dishnetwork. Not sure what is available on DirectTV but it is similar. I am hoping ESPN HD will become available soon...real soon. Also HDnet.
hoosier, check out your local cable co. and see what if anything is available in HD. The only reason I switched from cable to satellite is RCN cable offered nothing in HD.suds, suds and more suds! -
where I am moving there is no cable.Dodd - Battery Preamp
Hoosier,
The 921 also contains a HD local tuner, so this would not be an issue. As far as upgrading from another unit. Yes I would think you would have to pay extra for this unit or they may offer a discount to users like they are doing with their current PVR tuners."The only way to get rid of a temptation is to yield to it." -
hoosier,
one small consideration that I think worth a ponder is the fact that, if you go with HD DTV, you can install one triple LNB dish, and my understanding is that if you go with Dishnetwork, you have to have two dishes installed. That's what the installer told me, obviously I had a cow for having two dishes when I don't have to. My .02I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Dish is coming out with a multi-satellite dish, so you will have one dish I guess.
