Cable hook up question, please help!
annat
annat Posts: 1
Maybe this is the wrong place to post this, but I have a quick (and hopefully easy!) question that I'm thinking one of you might know the answer to. I am going to have cable television hooked up in a couple weeks (first time ever having any sort of tv besides over-the-air), and my television only has the "antenna" hookup on the back. Will the cable box be able to be hooked up to that? And if not, is there something I can buy that could hook on to make it work?
Any information would be greatly appreciated!!
Thanks! :D
Post edited by annat on
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    Radio shack will have the adaper you need.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2008
    Depends what you mean by antenna conector. If it's a standard coax connector you should be all set. If it's the two screw terminals, it will require a an adapter.
    Either way, the cable company will hook it up for you, and supply what's needed, you won't have to buy anything.
  • DeepFreeze
    DeepFreeze Posts: 11
    edited October 2008
    Typically the person installing the cable will have everything they need to get you up and running. It shouldn't cost you anything, except for your time.
  • PGWarner
    PGWarner Posts: 1
    edited November 2008
    If your TV set is a truly vintage set, say before 1980, than you just might have two pair of 300 Ohm "flat-lead" screw terminals marked UHF and VHF. A 79 cent balun coil is all that is required to adapt that to the 75 Ohm coaxial F-connector from the cable box. It's more likely you have that same single (round-silver) coaxial f-connector marked "Antenna" In either case all you will need to remember is to keep the TV set tuned to either channel 3 or 4. That being the most basic, most newer sets also have a selection of auxiliary inputs with incrementally better picture quality. If you were to want high definition television, the HD cable box and the HD ready TV will require a component (grouping of 5 RCA cables) or an HDMI cable hook-up.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Go with Sat TV instead of cable you will not be hurting on the bill in a few months like cable
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • ben62670
    ben62670 Posts: 15,969
    PGWarner wrote: »
    Welcome to Club Polk! I have been to LRP a few times. Nice country there. You would expect a track out there like that. Very nice.
    Ben
    Ben
