Cable hook up question, please help!
annat
Maybe this is the wrong place to post this, but I have a quick (and hopefully easy!) question that I'm thinking one of you might know the answer to. I am going to have cable television hooked up in a couple weeks (first time ever having any sort of tv besides over-the-air), and my television only has the "antenna" hookup on the back. Will the cable box be able to be hooked up to that? And if not, is there something I can buy that could hook on to make it work?
Any information would be greatly appreciated!!
Thanks!
Thanks!
Post edited by annat on
Radio shack will have the adaper you need.Mains.............Polk LSi15 (Cherry)
Depends what you mean by antenna conector. If it's a standard coax connector you should be all set. If it's the two screw terminals, it will require a an adapter.
Either way, the cable company will hook it up for you, and supply what's needed, you won't have to buy anything. -
Typically the person installing the cable will have everything they need to get you up and running. It shouldn't cost you anything, except for your time.
If your TV set is a truly vintage set, say before 1980, than you just might have two pair of 300 Ohm "flat-lead" screw terminals marked UHF and VHF. A 79 cent balun coil is all that is required to adapt that to the 75 Ohm coaxial F-connector from the cable box. It's more likely you have that same single (round-silver) coaxial f-connector marked "Antenna" In either case all you will need to remember is to keep the TV set tuned to either channel 3 or 4. That being the most basic, most newer sets also have a selection of auxiliary inputs with incrementally better picture quality. If you were to want high definition television, the HD cable box and the HD ready TV will require a component (grouping of 5 RCA cables) or an HDMI cable hook-up.
Go with Sat TV instead of cable you will not be hurting on the bill in a few months like cableHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Welcome to Club Polk! I have been to LRP a few times. Nice country there. You would expect a track out there like that. Very nice.
Ben
