should i biamp Rti A3 speakers with Csi A4 not biamped?
birdguy
birdguy Posts: 5
I just got the Rti A3 and Csi A4. I have a Onkyo SR606 receiver that is capable of biampng the L/R. If I biamp via the receiver to the two Rti A3 for L/R, will the center Csi A4 be underpowered (it's not biamped)? Does biamping via the SR606 double the output to the speaker, or is each biamped channel's output halved? If so, what's the best way to set these speakers up? Should I just skip the biamping altogether?
Post edited by birdguy on
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited October 2008
    Biamping normally doubles the power you send so you may end up with a differance in volume from the fronts vs center when playing all three. You could adjust this to equal out in the end but might be more trouble than it's worth to you.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • ben62670
    ben62670 Posts: 15,969
    edited October 2008
    I would skip BiAmping with a receiver. A nice set of wires wuld make more of a difference.
    Ben
    Ben
