Pioneer Elite VSX-82TXS Receiver
criverajr
The Cleansing continues:
Need to sell purchased at 6th Avenue electronics. For sale is an awesome receiver with HDMI switching. It is the Pioneer Elite VSX-82TSX and features 130W x 7. Rated a 8.75/10. Pioneer's high-end 7.1-channel A/V receiver is tightly packed with a full range of top-notch features, including a Faroudja HD scaler that converts all analog video inputs to your choice of 480p, 720p, or 1080i resolutions over the receiver's HDMI output. It offers three 1080p-capable HDMI inputs and highly accurate autosetup. The THX Select2 certified receiver is also XM-ready and--offers iPod compatibility. All accessories included. Paypal adds 3%. Asking 475.00 shipped, or 450.00 if you pick it up. original box, remote, and Manual. Let me know. Pics to follow.
C
PS: Will be selling my Tall Stools and table from my pool room shortly, in mint condition.
C
Post edited by criverajr on
Bump
I found the ipod dock hookup cable, so all cables are included set-up mic, remote, manual, warranty cards.
CRj -
Bump
450.00 shipped
425.00 local/400.00 if picked up this weekend -
This is a great reciever. I am using one now.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Absolutely agreed. I had one of these for a few months and it sounded great for a receiver. HDMI works flawlessly, sweet integrated ipod cable, looks great. I actually preferred the sound of this Pioneer to my Onkyo 805.
Yep. It sounds great for music as well.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Thanks guys,
A little extra, will throw in a Avia (Ovation) set-up dvd with the color swatches.
C -
Hi this newbie in Seattle would like to buy
JM -
go ahead an send me pm if you still have
JM -
Can't seem to find specs online. Preouts?
Yes, it has 7.1 preouts. Works great as a pre-amp with pure direct for 2 ch. listening too.
Bump,
Going on the Gon tomorrow.
CRj -
Thanks, Jeff...
Specifications:
Amplifier section
Continuous average power output of 140 (or 130)
watts* per channel, min., at 8 ohms, from 20 Hz to
20 000 Hz with no more than 0.09 %** total harmonic
distortion (front).
Continuous Power Output
(20 Hz to 20 kHz, 8
Ω
, 0.09 %)
Front. . . . 130 W + 130 W (82TXS), 140 W + 140 W (84TXSi)
Center . . . . . . . . . . . . . . . . . . 130 W (82TXS), 140 W (84TXSi)
Surround . . . . . . . . . . . . . . . . . . . . . . 130 W + 130 W (82TXS)
Surround back . . . . . . . . . . . . . . . . . 130 W + 130 W (82TXS)
(1 kHz, 6
Ω
, 1.0 %)
Front. . . . 160 W + 160 W (82TXS), 180 W + 180 W (84TXSi)
Center . . . . . . . . . . . . . . . . . . 160 W (82TXS), 180 W (84TXSi)
Surround . . . . . . . . . . . . . . . . . . . . . . 160 W + 160 W (82TXS)
Surround back . . . . . . . . . . . . . . . . . 160 W + 160 W (82TXS)
Total harmonic distortion. . . . . . . . . . . . . . . . . . . . . . . 0.05 %
(20 Hz to 20 kHz, 120 W, 8
Ω
) (82TXS)
(20 Hz to 20 kHz, 130 W, 8
Ω
) (84TXSi)
Audio Section
Input (Sensitivity/Impedance)
LINE. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 mV/47 k
Ω
Frequency Response (LINE). . . . . . 5 Hz to 100 000 Hz dB
Output (Level/Impedance)
REC . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 mV/2.2 k
Ω
Tone Control
BASS . . . . . . . . . . . . . . . . . . . . . . . . . . .± 6 dB (100 Hz)
TREBLE . . . . . . . . . . . . . . . . . . . . . . . . .± 6 dB (10 kHz)
LOUDNESS. . . . . . . . . +4 dB / +2 dB (100 Hz / 10 kHz)
(at volume position –40 dB)
Signal-to-Noise Ratio (IHF, short circuited, A network)
LINE. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 dB
Signal-to-Noise Ratio [EIA, at 1 W (1 kHz)]
LINE. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 dB
* Measured pursuant to the Federal Trade Commission’s
Trade Regulation rule on Power Output Claims for Amplifiers
** Measured by Audio Spectrum Analyzer
Composite Video / S-Video Section
Input (Sensitivity/Impedance) . . . . . . . . . . . . . . . 1 Vp-p/75
Ω
Output (Level/Impedance) . . . . . . . . . . . . . . . . . . 1 Vp-p/75
Ω
Signal-to-Noise Ratio . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 dB
Frequency Response . . . . . . . . . . . . . . . . . . . 5 Hz to 10 MHz
Component Video Section
Ω
Ω
Frequency Response . . . . . . . . . . . . . . . . . . 5 Hz to 100 MHz
FM Tuner Section
Frequency Range . . . . . . . . . . . . . . . . .87.5 MHz to 108 MHz
Usable Sensitivity . . . . . . Mono: 13.2 dBf, IHF (1.3 μV/75
Ω
50 dB Quieting Sensitivity . . . . . . . . . . . . . . .Mono: 20.2 dBf
Stereo: 38.6 dBf
Signal-to-Noise Ratio . . . . . . . . . . . Mono: 73 dB (at 85 dBf)
Stereo: 70 dB (at 85 dBf)
Distortion . . . . . . . . . . . . . . . . . . . . . . . . Stereo: 0.5 % (1 kHz)
Alternate Channel Selectivity . . . . . . . . . . . 60 dB (400 kHz)
Stereo Separation . . . . . . . . . . . . . . . . . . . . . . . 40 dB (1 kHz)
Frequency Response . . . . . . . . . . . . 30 Hz to 15 kHz ± 1 dB
Antenna Input . . . . . . . . . . . . . . . . . . . . . . . 75
Ω
unbalanced
AM Tuner Section
Frequency Range . . . . . . . . . . . . . . . . . .530 kHz to 1700 kHz
Sensitivity (IHF, Loop antenna) . . . . . . . . . . . . . . . .350 μV/m
Selectivity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .25 dB
Signal-to-Noise Ratio . . . . . . . . . . . . . . . . . . . . . . . . . . .50 dB
Antenna . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Loop antenna -
Jeff Beaird wrote: »Sami, it's called Google... try it.;)
I did, none of the sites I found listed if it had preouts or not. Pioneer's website didn't have the model and no mention of them either on the specs above.
I would use it as a preamp if I was to buy, just so I could get the new codecs. Too many expenses right now so I think I'll pass. Bad timing. -
You have to click the "Older Models' link
Here ya go.
And it does appear to have preouts (top middle)
From the specs:Audio Pre-Output 7.1
Edit: Oh yeah and Gebby said so in post #14____________________
Pool: Atrium 60's/45's -
Yes, he did. I was just responding to Jeff's smartass comment. Wasn't finding the info online and asking here was going to be quicker.
Looks like no DTS-MA decoding either so I'm out. PS3 would decode it IIRC over HDMI anyways but I think I'll stick to my decision to keep the HK and get a standalone with analogs when they become cheaper. -
Blowout for the forum 375.00 plus shipping, can't get that around here, on the Gon for more but this will be a 24 hour thing, let me know. Paypal add 3% will get it in the mail on Monday
CRj -
Damn, ok, you baited me in. Lets do it. If I don't like it vs my HK AVR7200, I'll pass it to a friend of mine. I'll send in PM.
Sold to sami****
Nice grab Sami. It's a really great receiver. Pretty much my top choice without new codecs. Enjoy
Yep, looks decent enough, we will see how it compares to the HK in terms of 2ch performance. I'm using Sherbourn 5/1500 for amplification.
PS3 should be able to pass DTS-MA through the HDMI as LPCM so I shouldn't have the need for internal decoding on the receiver, just the HDMI connection which is missing from my HK. -
Sold
