Subwoofer pops
Hello,
For some reason my subwoofer makes a loud popping sound when I turn up the volume, while watching a blue-ray movie and there is an explosion, or gun fight scene.
Is this what people call clipping? Did I blow out my subwoofer?
I usually do not push my system very loud. I never notice it while watching from my directv (Dolby Digital).
Any ideas? When I listen to CDs on the same blu-ray player and crank it up, the subwoofer sounds great, no popping.
Thanks guys,
Lonwa
Thanks guys,
Lonwa
Sometimes good command decisions get compromised by bad emotional responses."
Post edited by lonwa on
no, only during loud explosions or gun fights... power on its fine.
It is not always consistent either.Sometimes good command decisions get compromised by bad emotional responses." -
possibly the sub bottoming out? Do you have a subsonic filter set? What sub are you using?Mains.............Polk LSi15 (Cherry)
I guess it could be some sort of overload/clipping. Would you be happy using the sub at a volume that is below the "popping" level? Whatever the noise it, it can't be good for your sub.
I have the Polk PSW450Sometimes good command decisions get compromised by bad emotional responses."
i don't believe I have a subsonic filter set. To be honest I don't know what that is.
SorrySometimes good command decisions get compromised by bad emotional responses." -
That's the sub bottoming out. Back off on the gain a little - it's not good for your sub.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
