Subwoofer pops
lonwa
lonwa Posts: 83
edited October 2008 in Speakers
Hello,
For some reason my subwoofer makes a loud popping sound when I turn up the volume, while watching a blue-ray movie and there is an explosion, or gun fight scene.
Is this what people call clipping? Did I blow out my subwoofer?
I usually do not push my system very loud. I never notice it while watching from my directv (Dolby Digital).
Any ideas? When I listen to CDs on the same blu-ray player and crank it up, the subwoofer sounds great, no popping.
Thanks guys,
Lonwa
Sometimes good command decisions get compromised by bad emotional responses."
Post edited by lonwa on
  • zingo
    zingo Posts: 11,258
    edited October 2008
    Is the popping sound when the sub turns on?
  • lonwa
    lonwa Posts: 83
    edited October 2008
    no, only during loud explosions or gun fights... power on its fine.
    It is not always consistent either.
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    possibly the sub bottoming out? Do you have a subsonic filter set? What sub are you using?
  • zingo
    zingo Posts: 11,258
    edited October 2008
    I guess it could be some sort of overload/clipping. Would you be happy using the sub at a volume that is below the "popping" level? Whatever the noise it, it can't be good for your sub.
  • lonwa
    lonwa Posts: 83
    edited October 2008
    I have the Polk PSW450
  • lonwa
    lonwa Posts: 83
    edited October 2008
    i don't believe I have a subsonic filter set. To be honest I don't know what that is.
    Sorry
  • curved
    curved Posts: 664
    edited October 2008
    That's the sub bottoming out. Back off on the gain a little - it's not good for your sub.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
