Quick HDMI cable comparison
olilugo
Hey all,
I am not a big audio or video expert, and I don't really believe in the bla bla so here is goes.
I purchased a Monoprise HDMI cable:
HDMI 1.3a Category 2 Certified Silver-Plated Copper CL2 Rated (For In-Wall Installation) Cable (24AWG) - 10ft (Gold Plated Connectors).
Here is the link:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024004&p_id=3659&seq=1&format=2
I also purchase an HDMI cable made by Panasonic.
Panasonic RP-CDHG30 High Speed HDMI Cable - 9.8ft (White)
Here is the link:
http://www.amazon.com/Panasonic-RP-CDHG30-High-Speed-Cable/dp/B000G62F88/ref=wl_it_dp?ie=UTF8&coliid=I25EZ468Z3SUKY&colid=2FPULQ8TGGCX1
The Monoprise is $23.85
The Panasonic is $33.79
A quick comparison, the Monoprise looks and feels very well made, is almost twice as thick as the Panasonic. The panasonic look like a regular cable
They both supposed to be 1.3a capable
Both cables are category 2, and support Bandwidth: up to 340 Mhz
The Panasonic cable has three other specs which the Monoprise did not mentioned
1. The Panasonic cable is rated high speed
2. The Panasonic cable supports 10.2Gbps
3. The Panasonic supports 8-16bit 1080p for video and sound.
The test I performed is a very simple one, I put connected an upscale dvd player and a TV that support 1080i. I did not test the sound capabilities because I dont own a receiver that has HDMI.
The main differences in video are:
The Panasonic has a bit more resolution in the colors (colors look brighter), when there is movement in the movie the Monoprise was not able to keep up, the Monoprise gives blurred action, with the panasonic the movement is generated as it supposed to be and you get not fuzzines or blurr. I also notice the Monoprise gives a more grainy picture than the Panasonic.
Well that is it I hope this is helpful to anyone looking for an hdmi cable.
Here is the link:
Here is the link:
Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
TV: Sony KDS60A2020
DBP: Sony DBP-S350
Post edited by olilugo on
Sounds like the Panny is worth the extra coin. Thanks.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
When it comes to HDMI cables its just 1's and 0's, cable quaily may have a difference, but sound/video should be the same all day. Nice write up though.Shoot the jumper.....................BALLIN.............!!!!!
HDMI cable errors show up as dropouts and sparklies, not blurring of motion or color and brightness differences.
Like that compared to a BlueJean Cable HDMI nicely built but never compared one the the other.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Like that compared to a BlueJean Cable HDMI nicely built but never compared one the the other.
I use Bluejean HDMI BJC Belden Series-1 Bonded-Pair Cable, and I have to admit I do like the build quality of them. And you dont spend a fortune for them either.Shoot the jumper.....................BALLIN.............!!!!!
Yes the same cable I use, I very pleased with the HDMI cable. They also make a very nice S-Video cable if anyone have as the need.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Yes the same cable I use, I very pleased with the HDMI cable. They also make a very nice S-Video cable if anyone have as the need.
Yep, I run a full stack to the projector, Though I dont connect them all, they are all there if needed, Svideo, component, 2x HDMI. Agreed, very nice quality cables.Shoot the jumper.....................BALLIN.............!!!!!
Olilugo, none of the effects that you report can be due to the HDMI cable. If an HDMI cable has signal losses too high for length of the run involved this will appear as electronic noise or sparkles in the picture, not the effects that you mention. For a short 10' run such as was involved in your case a 24ga cable is more than sufficient and even a 28ga cable would work well. Your review undoubtedly was well-intentioned, but it's misleading to possible future purchasers.
There's nothing misleading about his first hand experience. What's misleading is your 2 cents as you have no experience with the cables he used.The Panasonic has a bit more resolution in the colors (colors look brighter), when there is movement in the movie the Monoprise was not able to keep up, the Monoprise gives blurred action, with the panasonic the movement is generated as it supposed to be and you get not fuzzines or blurr. I also notice the Monoprise gives a more grainy picture than the Panasonic.Political Correctness'.........defined
President of Club Polk -
thanks for your review its always shows well when someone reports what they actually heard or saw with any audio gear or wire, nothing like emperical data.
dont take the self-crowned know it alls here to seriously, they have an inner need to expound their spin and shout it from a mountain top.
RT1 -
Thanks all,
My intention was not to misslead anyone to purchase one hdmi cable over the other.
It was simple comparison between two cables I happend to purchase. I think these two cables are affordable enough that their price difference is amost not a point since I had to pay shipping for the one I bought from monoprise.
I was just curious about the monoprise cable since everyone gives good feedback about their product.
As I stated in my original thread (at least I think I did), I am not an authority on sound nor video, nor did I perform a scientific test on both cables. I really just plug them in and I used the same chapter in the movie to compare both cables.
I don't claim to know why I saw bluriness or why one of the cables seam to have sharper (better greens, better blues, … you get the point) colors.
I will not specualte, since I don’t know what is making it happen.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
TV: Sony KDS60A2020
DBP: Sony DBP-S350
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
Well I feel you did a fine job in comparing what you seen, and what was used. It was to me you seen the difference of the construction of the two cables that is all.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Again, excellent review.Shoot the jumper.....................BALLIN.............!!!!!
That's fascinating. It might be interesting to see if someone can buy say, 5 or 6 brands of HDMI cables (rated the same), and do a review themselves, plus allow a demo group to start for individual testing on your equipment. Then people can see the differences themselves and write about what equipment that had hooked up to everything.Current Setup:
Yamaha AX-450 Amplifier
Yamaha YST-SW216 Sub
Sony DVPNC800H/B CD/DVD Player
Samsung LNT2653H LCD TV
polkaudio R150's -
I volunteer you. Please post the results when you are done.Political Correctness'.........defined
HA, ohh brother I should have seen that one coming. If I fall into a few bucks to spend on cables I might just do that...Current Setup:
polkaudio R150's -
Would the results that OLILUGO reported be for his set-up only.
People using different equipment and different setting might see something
different on there system ?Equipment
Panasonic TC-P54S2 Plasma
Scientific Atlanta DVR
ONKYO TX-SR705 AVR Pre/Pro
Outlaw 7125 7 CH Power Amplifier
Toshiba A2 HD-DVd
Panasonic BD-30
Harmony 550 remote control
LSi9 ( Mains )
LSiC ( Center )
PSB Ambient 2 Dipoles
SVS 20-39 PCI Subwoofer
